Ford threadlockers?
moby4dick
New York
Michael
2018 GT350R
To try and right this ship and get back to the question ask about threadlocker, the pink is low strength, blue is medium strength, and red is high strength. Each color has a few different variations for primered, primerless, high temp, etc. There is also a green wicking grade that can to be used after the bolt is torqued. And last there is a green retaining compound that you definitely don't want to use. It is used on loose fits or very worn spline couplings.
A good rule of thumb is blue 243, which is primerless, is a good all around threadlocker that can still be removed. Now the mentioned colors and numbers are referring to lock tite brand products.
So would the pink colored threadlocker on the bolts be equivalent to Loctite purple then?
And re tires, PS4S, OE pressure 33# all around.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
As some others suggest. Shocks are step 1 for that floating feeling.
OP stated he has magnaride, unless the controller is dead it shouldn't be floaty.
I think Steeda has a YT video of the IRS subframe moving in corners.
@tj@steeda
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Good good.
boB
boB
2019 GT PP1
K4fxd
NKY
There was no mention of any squishiness from the rear.
Drive it, then put some IRS braces on it, then report back.
tj@steeda
Timothy
@tj@steeda
This!
K4fxd
NKY
I know the vid Tj posted is on a drag launch but the subframe deflects when in corners also. It may not if the road is perfectly smooth.
gfcobra04
Conroe
Gary
2000 Cobra R, 94 Lightning, 2020 GT500
Have you aligned the car?
moby4dick
New York
Michael
2018 GT350R
Reporting back, I’ve had the car on track as well as some favorite back roads with the fast S turns mentioned. Very pleased with the results!
Rear no longer feels floaty and catching up with the front. Much more planted and feeling confident in the chassis. Definitely not placebo effect.
Alignment unfortunately need to be redone. My shop didn’t have their new rack installed, and their friends shop didn’t follow our request, so turn in not sharp.
