Glenn G
- Jul 3, 2015
- Kaiserslautern, Germany
- Glenn
- 15 DIB 6MT base Ecoboost
Quick physics lesson about pressure drop in intercoolers, all intercoolers have it but it's not a bad thing to a certain extent. Let me explain
a given mass of air at 200 degrees leaving the turbo occupies a hell of a lot more room than the same mass of air at ambient temperature., I'd be weary of an intercooler that didn't have at least a 1.5 to 2 psi drop across the core because that means it's not cooling the charge much. Second ly you do need to build some restriction into your core. The longer the air remains in the core, the more time it has to transfer heat.
To accurately mesure pressure drop, one needs to see the air pressure at the intercooler entrance work which our cars do not have a sensor. You also need the temperature for which our cars also have no sensor, lastly you need to measure the mass of air moving in for which we also have no sensor.. Ford however does some clever math to infer those readings. We do have sensors at the exit of the cooler for pressure and temp. Once you have this data you can calculate what the required drop should be for the temp drop.
