Ford Performance released its PP2 replica wheels
AZHowln50
Gilbert, AZ
Jason
2019 Mustang GT Premium PP1 10 Speed Auto
I came to this thread for this exact post. I'm running 19x10/19x11 wheels with 295/35 and 305/35 tires. The issue I have comes at the very end of the steering. There is contact at the very bitter end of the steering radius. Obviously not an issue for racing but street drive, this is something to consider.
With these 19x10.5 +24 wheels, are my calculations off when I'm showing a 6.69 backspace? My 19x10 +35 have a 6.878 backspace... so it seems running these may solve my contact issue? Had to blink twice at this wondering if I miscalculated somewhere.
As far as the math and clearances go I would have to refer you to an expert like @Brian@BMVK to answer this question. My driving was on the street and I did a bunch of tests with no contact or rubbing.
Performance nut
TX
2018 Mustang GT A10
I'm hoping @NightmareMoon will chime in as well. 10.5" wide seems to be the optimal width for a 295/35-19 tire.
BTW, I think someone mentioned the GT350 wheel would be fine on the front. With a +30 offset, won't this increase contact vs the +24mm PP2 wheel?
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
I ran stock GT350 wheels for about a year before trading them for the stock PP2 wheels, and used the same 295/35-19 front and 305/35-19 rear tires on both sets of wheels. No issues whatsoever with the GT350 wheels. Getting a little rubbing in the front with the PP2 wheels when I bottom out the suspension, but I also lowered the car a little so I'm sure that's part of the problem (soon to be rectified). The GT350 wheels were paired with the stock PP1 suspension.
PP2 wheels are 19 x 10.5 +24 front, 19 x 11 +48 rear.
GT350 wheels are 19 x 10.5 +30 front, 19 x 11 +62 rear.
Jonyxz
San Juan, PR
2019 5.0 401A 10R80
I think a 5mm spacer would be enough to solve your issue. It would change your offset from +35 to +30.
As Mike said the gt350 wheels with +30 ET work well on 295 tires.
Performance nut
TX
2018 Mustang GT A10
Speaking of... where do you buy GT350 wheels? I don't know the part number and I cannot find a source for them anywhere. Only wheels that come in those sizes seem to be custom wheels which I have no doubt are lighter. 10.5 wheels for Mustangs seems to be a rare breed.
Mikepol2
Pittsburgh, PA
I bought my GT350 wheels used here on 6G, they seem to pop up fairly regularly. Have seen them on Ebay too. Never would have gotten rid of them for anything except PP2 wheels.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
As mentioned above, a 10.5" ET 24 is a stock PP2 fitment and those run 305s. I concur its a 6.7" backspace. Its pretty generous on the inside clearance, assuming you're not doing anything funny like running camber bolts.
As for the ideal width for a 295 - a 10.5" is square and perfectly fine..... but ideal would be to stretch it on an 11.5" wheel (sharper handling), not that an 11.5" is easy to fit up front... Lets call 'ideal' an 11" wheel (ET 26) ideal for these purposes.
kart3l
Bethesda, MD
15'Mustang Ecoboost PP
Hello guys,
Newbie here. I have a PP2 (10.5 front and 11 rears) and currently have 275/35R19 Continental All Seasons. If I get the wheels below (9.5/10 setup), can I install the 275's that I currently have?
I need a spare set for winter/summer and want to put stock tire sizes 305/30R19's on the original wheels that I have now after moving the 275's to the wheels below. I read that you guys recommend 285's but the 275's I have now only 9K miles on them and don't want to trash them. Or, is it a must that I get 285's?
Would I experience an issue? I see that this warning:
ATTENTION: The M-1007-DC1995MB and M-1007-DC1910MB sizes are intended for use only on vehicles NOT originally equipped with the Performance Pack Level 2 option. Although these will fit other 2015-2020 Mustangs, use on Performance Pack Level 2 vehicles may result in chassis clearance issues.
Just need y'all gurus' blessings.
Thanks.
Well the decision has been made. I purchased these wheels instead of the SVE.
I went for the 9.5/10 wheel setup and I'll continue to use my factory PP1 tires. Maybe I'll go a little wider in the rear next time I need new tires but not by much maybe like 285s.
I purchased the wheel kit M1007KDC19MB
instead of purchasing each wheel individually, comes with the pressure sensors.
I ended up paying much more than what the sve kit cost but I like the idea of having a factor spec setup I'll even be able to use my existing lug nuts and locks, probably even the same center cap since the Ford performance caps I believe are the same size as the PP1 caps.
Not having to worry about rubbing, offsets, spacers, or studs was the deciding factor for me. I know getting new wheels and keeping all the same sizes is not sexy but that's okay for me :)
gismo4
gismo4
TX
2018 Ford Mustang GT PP1
Hello guys,
Thanks.
To all your questions, you'll be fine. But I have to ask since you have a pp2. Why not just get the pp2 sizing?
Dave TBG
Patiently waiting...
New Jersey
'19 EB 201A, '86 Porsche 944
He mentioned that he wants to use a set of all seasons that he already has, I'd assume for winter use.
For the OP, your 275s will be fine on 9.5" wheels. Depending on where you live that is probably a solid choice for winter use. 285s would be better on 10" wheels but, for snow, I'd probably not go that wide.
gismo4
gismo4
TX
The post states that they have pp2 wheels with 275 all season tires installed and the end goal is to install 305 tires on the stock wheels after moving the 275 tires to a winter set of wheels. If they know the 275s fit on stock pp2 wheels, why not stick with the pp2 sizing? I'm only curious because I see a benefit in having the same size pp2 wheels in the long term.
kart3l
Bethesda, MD
Thank you guys, really appreciate it.
My concern is that the tires are a bit stretched on the 10.5/11's and prone to curb rashes, and having a shorter sidewall, etc, hence my thinking of going smaller on the wheels. Given that the OEM size ones are on sale, you guys recommend I go for those instead? Please correct me if I am wrong.
I can get the 9.5/10 pair vs 10.5/11 at the same price at CJ Pony Parts.
Or, how about a square setup of 10 inch wheels all around with my 275/35R19's wrapped?
I just need a spare wheel set to utilize my 275's and this is becoming harder.... Thank you again.
gismo4
gismo4
TX
Best thing would have been to have the SVE 10 inch square setup... I could've rotated tires as well... Ahh one can only wish for. And these retailers don't sell the 10 inch wheels.
That makes sense since the pp2 wheels poke. However, you may get used to running the 9.5/10 setup and then when summer comes, you may get too close to the curb with your pp2 wheels. I have 285/35 on my 19x10 SVE wheels and there's very little protection for the rim. I'd imagine 275 wouldn't really help the 10" but maybe the 9.5". Unless of course you have tires designed to help protect the rim. Also, you mentioned the SVE wheels. If you hold off, you may be able to get the SVE wheels before winter. There's so many variables, but it might be worth waiting to get the wheels and wheel size you want.
kart3l
Bethesda, MD
Yeah, I guess I may hold off and do that. You have no protection?! Try running 275's on 10.5/11 inch wheels lol. I park about a foot away from the curb because of that. I will post pictures later.
You can do a side by side using this: https://tiresize.com/comparison/. If you go 285, i would stick to a 40 sidewall since you don't plan to lower your car. 285/35 will increase that wheel gap. I would stay with a 40 sidewall until you start thinking about going 305 and up. The below is a 285/35/19 square setup on stock height.
Hi Gismo, is this 10 inch square setup? Should I go for this setup with the replicas to use my 275's? I guess the Ford wheels and the SVE wheels have different offsets, but wanted to hear of your opinion.
This is in reference to the post you posted on 4th page of the Blue Mustang running 275's on square setup.
And you know..., I gave it a thought. And you are right regarding getting used to a particular setup. It may be best that I just get the same wheel size as I am already used to it and deal with the tire stretching issue. It is only during fall/winter anyways. But the downside is less sidewall, and stretched tires... Decisions decisions....
Mikepol2
Pittsburgh, PA
If you look on the Tire Rack website in their detailed specs for each tire, there is a rim width range for each tire size.
