Ford Performance oil separator
Amacron
Louisville
2019 GT350, 2015 Mustang GT Premium
Just purchased the oil separator from ford performance.
M-6766-A50
the one I received didn't have the hole in it for the wire harness. Anyone else run into this? View attachment 432611
Amacron
Amacron
Louisville
M-6766-A50
m4a1mustang
DC
'19 GT350, '19 XC90, '13 335i
I believe that's an older version, because mine (and pretty much every single one I've seen) does not have that hole.
bozzy
Alberta, Canada
www.rdsc.ca
2019 GT350
Ford Performance seems to be on a parts commonality streak right now. I bet this was also updated when the GT500 predator motor was built.
key01
Chicagoland
2017 GT350 now gone to a great home.
Doesn’t the predator have the built in unit with the crankcase oil return line? I only have the two holes in my FP separator
drummerboy
SoCal
'19 GT350
I don't remember there being a hole for a wire harness. Your image isn't loading, here is a screenshot from Amazon:
Amacron
Amacron
Louisville
this photo is from FP instruction PDF for this part
Amacron
Amacron
Louisville
The hole In that pic is covered up by the wire harness installed back into it
galaxy
St Louis
Mine didn’t have the hole. Would have been a nice touch, but meh, it’s inconsequential.
bozzy
Alberta, Canada
www.rdsc.ca
2019 GT350
Looks to be external. This OS is also included when you purchase the CF Track Pack option....
lenFeb
USofA
Len
2019 Shelby GT350 #K0110
Just drill the hole or leave wire as is.
JAJ
Vancouver BC
2016 GT350 Track Pack
I have an early one and it has the hole. Apparently, the hole was eliminated because it weakened the bracket. The mounting tab that curves off to the left in the picture would break off where the hole is, apparently. Anyway, the newer ones don't have it any more. Mine does and it's fine.
The Chairman
South TX
ā€˜09 GT500KR & ā€˜16 GT350 Track Pack & ā€˜20 GT500 HP
The first one they sent me had broken off in shipment. Was definitely a weak point in the mount. Don’t drill a new hole — you don’t need it.
Epiphany
Global
I like to disassemble things.
This is 100% correct.
Thank the Ford engineer behind the part, Ron Ewert, for listening and implementing a running change to the part that made it stronger.
Epiphany
Global
The hole was eliminated (not long after the separator was introduced) to mitigate fracture issues.
