Fitting Strut tower brace (OEM)
Egghead
Western sydney
Greg
2016 mustang gt
I'm surprised that the guys in the UK are saying the Ford racing brace will suit, as I thought they were exactly the same as oem, but just a different colour?
Any chance of pictures [MENTION=10325]Aussie Mate[/MENTION]?
That's why I was getting confused !!!??
quick duck
Melbourne, Australia
VZ Berlina wagon
there is an easy fix to this problem. You will need to... ohh thats right... all i know is carby upgrades. Oh well good luck :)
G RUSH
Perth
2016 V8 GT
thanks for reinforcing my opinion, thanks :paddle:
Hey [MENTION=18356]quick duck[/MENTION], I found the perfect custom plates for you - and they're still available here in WA!
quick duck
VZ Berlina wagon
Hey @quick duck, I found the perfect custom plates for you - and they're still available here in WA!
why would I want to say hello to a horse? :crazy:
but back to the OP, there is an easy fix. For most of the issues people here discuss ad nauseam, there is information readily available.
or you can keep reading Hybrid and a few others, who like to just repeat and repeat.... :barf:
jumby
Master Cat Herder
Perth
2013 300C Luxury
Hangon and Back up the bus mr duck - your first post on this thread was pretty much a bit of a whinge (for why I had a dig) and this isnt a first for you - so in affect pot calling the kettle black.... MUCH :ninja::ninja:
quick duck
VZ Berlina wagon
Was no winge, don't know how you come to that opinion.
I simply said I know the fix, but my input is rarely appreciated or simply told to butt out and that I am wrong (when not) and there is a few here who find it amusing to put people down. I doubt you will find one post where I do winge, I might state my opinion, if that doesn't agree with yours, it is far from whinging nor attempting to ridicule.
But you can jump on the bandwagon too if thats far more simple for you to acheive. :paddle:
but again, back to the OP... yes its a simple known fix to get the strut brace to connect correctly.
Bradek
Perth, Australia
Brad
Mustang 2016 GT
Shit i quite like those plates :) might take them myself if no one else wants them.
WILDB
Australia
Will
2017 GT convertible Oxford White
The fix is to use a die grinder and adjust the shape of the cutout on the right side.
Problem solved, no shims or spacers should be needed. I'll be doing this next week when my car is delivered, so I'll take some photos then.
Bobsp12
Super Moderator
Moderator
Adelaide, South Australia
lots of Fords
I just had a look at my brace WILDB, there is certainly a difference between the two sides, but it's not much to have to grind off, a couple of mil would be enough. Nice work if that does the trick, and nicely out of sight with a bit of silver touch up paint.
Hunter
Sydney Australia
Karl
2016 Mustang GT Fastback PP Manual
Ok master yoda. To save me typing into Google would you please enlighten me to the easy fix?
Centurion07
Hampshire, UK
2015 GT
Hi all.
I've now sent pics of the brace fitted with the spacers between it and the K-brace as per my thread http://www.mustang6g.com/forums/showthread.php?t=41179 so am now waiting to hear what they plan to do as it clearly needs a bit of re-engineering.
If you check the first batch of photos I tagged Steeda in, you can see just how much depth would need to be ground out of the Steeda strut brace. The pic below gives you an idea of the width. Essentially half of that connection needs grinding away which is not feasible.
I was asked to fit the spacers to check for bonnet clearance, probably not as any kind of permanent fix.
FYI, here is a pic of the area that would need to be ground away to ensure it clears the K-brace. As you can see, it's a considerable amount and not something I would want to be doing. The top edge of the red blob is the current shape of the bracket. The lower edge is where it would need to be ground down to, in varying degrees, in order to clear the K-brace.
I can't speak for the OEM brace but a UK member has said it went straight on his car with no issues. He was asked for pics though and as of yet has yet to provide any. :shrug:
mkforks
hertfordshire UK
mustang v8 r/h/d to come
I fitted the ford oem strut brace from usa
fitted straight on with no gaps or spacers needed
don't know how mine is different but fits flush on top of the k brace ok
