Exterior rear view mirror goes crazy when changing seat memory
willywind
US
2019 Mustang Premium
Hi there,
sometimes when I switch between seat memories, the rear view mirrors start adjusting and it appears they reach the end of the range and they start making a clicking noise. The noise is similar to the sound of a nut reaching the end of the lead screw. The mirrors jerk a little bit. Have any of you encountered this problem? This is a loud noise and it doesn’t happen all the time so I suspect this should not be normal. Thoughts? Thanks.
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
Sounds like the mirror adjust control is activated and held until it reaches the end of its travel. That's normal when the mirror adust is held 'on' for too long. I'd make sure that your mirror control selection switch is in the middle notch (neither left nor right mirror selected) and that youre not accidentally engaging the adjustment when you press the seat button. Otherwise, there's probably a wiring problem in the door around the seat selector button.
Jccams
Michigan
Jeff
2019 GT Premium, PP1, Magneride, A10
Hi there,
My 2019 did the same thing when I brought it home with 27k on it. I was setting a seat preset and the passenger mirror did the same thing, not sure if the drivers did too. I have no idea what happened. I never switch seat positions so I haven't seen it again. Let me know if you find anything.
350 Feet
CA
Dean
2018 Shelby GT350 Orange Fury,'06 F350 4x4, '22 Tacoma 4x4 Sport, '06 BMW 330xi,
Hi there,
It’s all rumor mind you, but I heard when that happens it’s 7 years bad luck.. :) Those electrical gremlins are the most annoying. Good luck.
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
Mine does the same thing, I simply choose a different memory setting then back to the one I selected in the first place. Never bothered to figure out why...
I Bleed Ford Blue
North East OHIO
My 17 did that. When it happened, I just hit the memory button again and it will stop.
Tucsonjay
Northern Virginia
Jay
2019 Ford Mustang GT Premium 401A 6spd
My 19 GT Premium does that every so often for no apparent reason. I just choose a different memory setting and it stops, then I go back to my preferred MyColor scheme.
Not the only glitch I've seen, the dash has blinked a couple of times and once the car just died and I had to restart. But they're so rare I never really sought a cause for any of them.
Don H
Don
2019 GT PP1
This fixed mine.
SSM 49217 - 2015-2020 Edge/MKX/Nautilus/F-150/Mustang - Mirror Click And/Or Ratcheting Noise - Built On Or Before 18-Jan-2020
Some 2015-2020 F-150/Mustang, 2016-2020 Edge, 2016-2018 MKX and 2019-2020 Nautilus vehicles built on or before 18-Jan-2020 may exhibit a mirror click and/or ratcheting noise when using memory functions or easy entry/exit function. This may be due to the software in the driver door module (DDM) and passenger door module (PDM). To correct the condition, reprogram the DDM and PDM with the latest software level of the appropriate Ford diagnostic scan tool. For claiming use causal part 14B291 and applicable labor times in Section 10 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
2016 - 2020 CAR: DQ CD539N EDGE
2015 - 2020 TRUCK: FC P552N F-150
2015 - 2020 CAR: ZG S550N MUSTANG
2016 - 2020 CAR: D9 U540N MK
lepak91
Redford, MI
David
2018 Ford Mustang GT
This fixed mine.
APPLICABLE VEHICLES
This fixed mine also.
Tucsonjay
Northern Virginia
Jay
This fixed mine.
APPLICABLE VEHICLES
Is this a dealer fix? Or can I do it myself?
I Bleed Ford Blue
North East OHIO
This fixed mine.
APPLICABLE VEHICLES
That makes sense. My 17 did it about once a week, but my 23 has never done that in the 2.5 years I've had it.
willywind
US
Thanks, all, for the info. I don’t think I can fix it myself so I’ll continue dealing with it. BTW, you can stop the problem by pressing any arrow that moves the mirrors.
m3incorp
Georgia/Colorado
James
One or the other of mine does it from time to time. I have a different setting for reverse that only changes the mirrors and not the seats. I select that setting, then go back to the drive setting, and it's good to go. I back into the garage to park, so I use the second setting a few times a month when I drive the car. Hmm, just checked my MyQ app and see I haven't opened the garage door in 25 days where the Mustang is parked. Looks like the temps will hit 60 this week, so better take it for a drive.
