rb92gt
- Jul 23, 2015
- Ponte Vedra, FL
- Ryan
- 2016 GT350 Cooled Tech
Holy hell guys, this is some next level kind of stuff here. A muffler is a metal box with a few pipes coming out of it, in our case one pipe in the front and two in the back. One in the back has a valve that opens and closes, the other does not.A current limited diode would be like a pressure relief valve, which I suspect is not present in the GT350 exhaust. No, Fluid Mechanics dictates that each "leg" of the exhaust has it's own flow impedance curve. This curve is characterized by the function: Pressure Drop = Constant x (Flow Rate)^power. The power is usually between 1.7-2.0. For the loud side, the constant and power is lower than on the quiet side (because there is less restriction), so the flow impedance curves have a similar shape, but the loud side is much more gradual, as pressure drop rises with flow rate. Thus, at high flow, the restriction of the quiet side increases much faster, resulting in continuously lower flow. I stand by my initial analysis.
