ESS Centrifugal Mustang Superchargers
Brad1810r80
Huntsville AL
Brad
2018 Mustang 2018 F150
Only changes are better DA and ran in drag mode this time so firmer shifts and little higher shift points. Still 2nd gear launch easing into it. 125mm pulley seeing 9 psi with the cooler weather. You can see on the dragy slip how much I’m easing into it. I can’t wait for track to open and do a 1st gear launch.
Next mod is 3.31 gears the car falls on its face hard when it shifts into 7th at 138 or so.
Nola504boy
HOUSTON
Walt
Boosted 2018 Mustang gt
I wanted to see the 60-130 slip
Brad1810r80
Huntsville AL
Brad
Here is the 5.30 one from that run. I’ve been a 5.10 on 120mm pulley and slightly better air.
Nola504boy
HOUSTON
Walt
Here is the 5.30 one. I’ve been a 5.10 on 120mm pulley and slightly better air.
That’s moving for the amount of boost you’re running. Similar to mine, but I was making around 14 psi with the Paxton full weight.
Nola504boy
HOUSTON
Walt
Those ESS blowers for the Coyotes seem to be the truth.
Rental18GT
Tulsa OK
Wesley
2018 Mustang GT base, 2004 Ford Expedition
Man, this is wild. I definitely want to get my hands on one of these.
DougS550
Indiana
Doug
What gear are you currently running?
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
Yeah he said 10 psi but that’s still insane time for only 10 psi with a supercharger.
I was responding to him saying it was a 7.5# pulley. To me it's a 10#, because that's what it makes. For some reason ESS calls it a 7.5#.
Brad1810r80
Huntsville AL
Brad
I'm loving it, I believe with a 1st gear launch I will go that hopefully or close to that. I won't ever have that good of DA at a track. But I know I'm losing some on not using 1st and centrifugal supercharger. Like I said earlier turner Ken from Oz tuning as been impressed he order one for his car to replace his odin.
Can’t wait to see this thing run a 9 second pass at the track with the 125mm pulley. With a 1.7 60ft or better it should go 9.7-9.8 no problem. Very impressive!
Brad1810r80
Huntsville AL
Brad
It doesn't make 10psi on a 75deg day maybe 8.5 or so. It only makes 10 40 or so and below.
Brad1810r80
Huntsville AL
Brad
I'd still really like to try to make one of these kits work with my 18 5.0 F150 that would be sweet.
