ESS Centrifugal Mustang Superchargers
DougS550
Indiana
Doug
That looks like a VERY nice unit....hmmmm....I might need that. Thanks for the link.
If it can read ethanol content, IAT etc AND, Close the throttle body and bypass valve when limits are reached, I would consider for my application.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I emailed the company and asked can it do those things and how
Normally closed relay on signal or ground wire on device you want to control. If lean condition, guage sends grounded output to relay. Which opens the controlled device circuit.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
You could also use a MAC valve on the signal line for BOV. If lean condition, open MAC valve which will dump boosted air to BOV.
Jhonda
Nc
Jason
2018 mustang gt pp1
22mpg is pretty good even on pump... I daily my 15' on E85 and average 11.5-12mpg (80% highway with the cruise set) maybe 17 or so on 93. And 90%+ of my driving is under 3k rpm. I'll usually go wot maybe once or twice a week and I usually limit it to a 3rd gear pull or something (traction limited when not running the good ole drag pack).
Do you have your imrc's deleted?
My imrc’s are still in operation. I’m still full weight stock motor and transmission.
Question for everyone on here.
I went to the track Sunday and ran 10.56@134. The da was 1850 feet and it was 81 degrees.
How much does heat affect our times?
I did get 25.5mpg on the way home with the windows down avg 73mph👍
ejs5.0
Austin, Texas
2020 Mustang GT 10r80
Quick question yall,
I just had my Fore L2 triple 285 installed yesterday and I’m noticing this noise from the passenger fuel pressure gauge.
The noise is loud enough that I can hear it from inside the car. Is this normal? Or is there an issue somewhere
LOL WUT
Illinois
19 GT
Not sure if the pressure fluctuation is normal. I have a single regulator so perhaps I am ill informed, but my pressure holds at a steady psi at the regulator gauge.
ejs5.0
Austin, Texas
Yup, I confirmed with the guy who installed and he said the pressure fluctuation is normal on the passenger side gauge. I have another pressure gauge on the drive side that’s at a standstill 50 psi
I’m really more concerned about the ticking noise it makes cause I didn’t notice it when I picked up the car
jmagnus87
Rhode Island
Magnus
2015 Mustang GT PP Comp Orange '22 Chevy Silverado
Anyone else getting locked out of first and reverse on their MT82 after the ESS addition? Mine is NOT happy 😂
daSNAK3
Warrenville, IL
Jake
2021 GT
Not at all. Luckily mine has been happy so far.
jmagnus87
Rhode Island
Magnus
daSNAK3
Warrenville, IL
Jake
2021 GT
jmagnus87
Rhode Island
Magnus
Mine is stock.
Yeah i replaced mine with the mcleod unit and i think i should have just kept the stock one 🤦‍♂️ fml
Mine lurches forward with the clutch pedal on the floor wheni start it
Zrussian13
Phoenix
Everything I've heard over the years says oem is best for the slave on these. What clutch are you running?
jmagnus87
Rhode Island
Magnus
Vengeance stage two twin disc. Guess I'll be pulling my transmission again this summer and putting an oem one back in. 🤦‍♂️
Zrussian13
Phoenix
I run tne oem slave with an lpx-hd and it holds up great. I did a lot of research when I installed it 40k miles ago and it seems most slave failures are aftermarket.
