Ecoboost Idle/RPM
Tpilger
Blk$tang1998
Tristan
2018 Mustang Ecoboost
So has anyone else had this issue before? I notice that when I have my car in park after driving for a while, the rpm’s sit at about 700 and slowly rise to about 900. No heat/ac on and my car always starts to slowly climb up. I also noticed that from time to time my car when coming to a stop, will dip down to about 595-600 and then when I come to a complete stop it’ll sit there for a sec and go back to 700. Plus I’ll be sitting at a stop and sometimes it’ll dip down to that point, the motor will shake a bit like poor idle and then jump back to 700 like it never happened. And those moments are always really random. Not sure if it’s normal but I’ve learned to deal with it at this point. Figured I’d start a new page on this topic because no one else(that I’ve seen)has mentioned this with their ecoboost.
Justgonna send it
NC
Ty
2019 GT 6spd ess G3 kit 120mm pulley , wendgerd tune & 2020 hpp eco
Are there any motor mods done to the car. Mine has a crazy idle flux between 750-890
2020Tang
DFW Texas
2020 mustang ecoboost
Have you checked for any pending codes?Spark plugs been replaced? Low pressure fuel sensor and purge valve been replaced? Check and see if you have the newer LPFS.
Tpilger
Tpilger
Blk$tang1998
Tristan
Oil catch can, new spark plugs. It’s been doing this since I bought the car
Tpilger
Tpilger
Blk$tang1998
Tristan
When I first bought my car, the first things I bought was a new LPFS and a JL catch can. I wanted to make sure my car wouldn’t possibly go ecoboom. It didn’t have the newer LPFS so I bought it and replaced it immediately when I first got my car. No codes as well. Only thing I’ve replaced recently was plugs and a purge valve but it’s been doing this since I’ve owned my car from the beginning
Justgonna send it
NC
Ty
Then it might just be a characteristic go to the car. You should reach out to parker performance. He dose a lot of ecoboost work.
KingKona
Virginia
Shlomo
2019 GT
I'll venture a guess the OP's car is an automatic/1080r.
OP, put the details of your car in the sig like like everyone else, that would be helpful.
2020Tang
DFW Texas
Great, sounds like you covered all the “main” things to replace.
I too also have a JLT catch can, you may want to check the fittings on it to make sure they are snug. Check and make sure hose clamps and tight. But I also agree that it just may be one of the characteristics of your car. Mine will idle a bit rough when I use the AC.
Tpilger
Tpilger
Blk$tang1998
Tristan
How do it do that? I’m still try to learn how to work this forum page. And I have a 18’ ecoboost with the PP and 10r80 transmission
KingKona
Virginia
Shlomo
2019 GT
Yes. With an automatic the idle will be stumbling around. That's just part of it.
I can't explain the site, you'll just have to mess around with your profile to figure out adding a signature. Maybe ask your kid or something.
Tpilger
Tpilger
Blk$tang1998
Tristan
Any vehicle I’ve ever owned never did that. It’d just idle at 750 and stay there when warm. I just wasn’t sure if this was normal on these mustang ecoboost. I’ve never heard anyone else mention this
Tpilger
Tpilger
Blk$tang1998
Tristan
I can't explain the site, you'll just have to mess around with your profile to figure it out.
Just wasn’t sure if someone’s mustang did the same thing without and oil catch can
sirben711
Missouri
Ben
2021 Mustang Ecoboost 10R80 w/ FP Tune
My mustang seems to idle very consistent right below the 750 rpm line while in drive. Say I am in a drive thru line and ive been waiting of a while and I put it into Park, my idle does go up to about 1k. I would say this is all normal.
I also have a catch can - but I can assure you my car had this behavior before the catch can.
Tpilger
Tpilger
Blk$tang1998
Tristan
Okay so I’m not the only one!! This is good news to hear!
