Dyno
arieso94z28
New Mexico
Hotter months typically show lower actual readings, but have higher correction numbers. Colder months show higher actual readings and lower corrected numbers. Just depends on if your using SAE or STD factors. Local to me in high elevation summer months, the dyno's in our area will show sometimes 22-24% correction.
I had Chris Groves at the Dyno Edge tune my mustang this past summer. He knows his stuff!
BadGTR
Belen, NM
15 GT Auto, 1400HP GTR
Hell yeah, he is top notch! Have known Chris for about 20 years. Definitely a great tuner and very honest business owner in the performance automotive industry.
robmustang201528
15 mustang gt302blown
LA
15pp
448 hp 405tq. Colder air and a couple of tweaks to the tune. .made 7 pulls. Very consistent. 443 was my lowest and that was my first pull
craigsix
overland park ks.
craig
2018 mustang gt
we have similar mods. mine is an auto with 3.15 gears 401/376. do you have a custom 3inch connecting pipes for the gibson catback?
robmustang201528
LA
15pp
Trying to upload pics of my dyno sheet. Tried to use the go advanced option but it won't let me attach
dubster99
Nor*Cal
2015 Ingot Silver GT PP
I doubt eliminating the bottleneck would make much power difference. Your auto will always dyno less than a manual due to the auto having more parasitic loss. They do better at the track because they shift faster, and shift automatically...easier to launch and drive. The type of dyno also makes a difference in the power number readings.
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
It kills me that our cars have so much "play" in the amount of hp from car to car. Yes UK a lot of it depends on the day, altitude, the dyno itself. But some guys are making around 450 and others are barely breaking the 400 mark with almost identical set ups. I have a feeling when I get mine on the dyno I'm gonna have a low number car
Jewishthunder
Bay Area
'15 Magnetic GTPP
It's all about the dyno and the day. Dyno's aren't meant to compare raw numbers from car to car. Dyno's under similar conditions are meant to measure the delta of your increases and to ease tuning so you don't have to street tune the whole thing.
arieso94z28
New Mexico
DA plays a big part in why our cars don't match up. Having put mine on the dyno at 6,000 elevation didn't help with the numbers, and to be in the 400's I am happy with that. Being close to sea level elevation you will always have a better running car. Thicker air equals happier engine, equals "MORE POWER".
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
Seems nowadays there are a lot more dyno manufacturers too. Back in the day I can only remember seeing Dynojet and Mustang dyno's. I'm used to Dynojets, and they're usually very comparable when using SAE numbers. I've had previous cars on three local Dynojets and they all dyno'd within a few hp with the same car.
BadGTR
Belen, NM
Typically corrected numbers at elevation show much more power on the readings then at sea level. Some manufacturers love to show the huge dyno numbers, specially those with boost.
whatsup62
Jupiter
Different dyno's produce different numbers , it's only a tuning tool. I have same mods ( different brands ) and my Dyno was 405/373. Haven't found a NA 2013 - 2015 in my area I can't out run. Power to pavement is where it's proven.
Jeffy_2010
Missouri
Taylor
Guys... I said that Ik that all these things play a part in numbers and etc. but I've seen two almost identical cars, running the same tuner on the same dyno and same day make prolly 20hp difference. That being said couldn't ever tell it on the street, just find it interesting not complaining
