dyno
robmustang201528
15 mustang gt302blown
LA
15pp
Probably a silly question but I have aftermarket wheels and tires on my car (20inch rims) will this effect my dyno numbers? I've seen cars make 370hp -395hp stock on the dyno, why does one car make more power then the other from the factory?
Guard5.0
Indiana
2021 Rapid Red GT500 CFTP
Because no two cars or dynos are the same. That being said, if you dyno the car on 10 different dynos you could possibly see that spread of 370-395 for the same car.
And can't imagine 20's dynoing higher normally due to weight but the difference I would think is negligible and certainly wouldn't show up on a dyno. Atmospheric conditions, traction, engine temps, alignment on the drum, etc. etc. would all change numbers.
stang9779
Denver
2015 GT Premium Performance Pack
No two cars are 100% the same. Just like no two people are 100% alike. As far as wheels I'm note sure if the weight matters. I know that forged wheels help with unsprung hp, due to less rotating mass. I think it only helps the engine rev quicker.
BathS550
Maine
2015 Mustang GT - 50th with PP
Different cars will themselves produce slightly different numbers.
Different dynos read differently (Mustang/Dynojet/Land and Sea/DD/etc) and even within a brand you will see differences between inertia based units versus eddy current versions.
Ambient conditions make a HUGE difference
Start modifying cars, and this changes even more. This is why when comparing sets of modifications from one car to another, it is important to ignore peak numbers, and actually look at delta (change)
When comparing my own modifications, I always dyno before, and after and do not rely on a previous sessions run (when possible) as the ambient conditions may be throwing off numbers slightly. Obviously when I installed my SuperCharger, I ran the car on different days, as this was unavoidable ... that being said, I knew I was going to be looking at a +-180whp change, and wasnt worried about nuance
However when I install my cat-back next week, I will run the car that morning, install the cat back, and then run it again ... to atleast narrow the window as much as possible.
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
The biggest difference is auto vs manual.
Tommy V
Brookly park Md
Tommy
Agreed 100%!!!!!!!!!!.
