Dyno question-different drive modes, different results?
94gt
Ohio
Mat
21' F150, 21' Mustang GT
Anyone do a pull in Normal/Sport/Track to see if there is any actual different in the HP made by the car? I know the drive modes make some changes, but it is something that can be quantified? Does Sport+ allow the car to make more HP than normal?
PaddyPrix
San Diego
www.youtube.com
Patrick
07 335is, 08 LR2, 13 Tahoe, 18 Mustang GT x2
There must be a slight something to it, as there's a plug under the stock airbox that the dyno operators are supposed to break for dyno testing. Those who track almost always break it as well, which forces off things like AdvanceTrak and Traction Control, instead of having to go to Track or disable it through a 10 second hold every time.
tom_sprecher
Living Race Car Free
Marietta, GA
2016 GT Premium PP 6MT Race Red
From what I recall no mode increases HP, they only remove nannies that keep rapid acceleration and subsequent wheel spin from happening.
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
There’s nothing in the calibration that can change engine power output based on drive modes.
Although it would be cool if there was.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
The throttle response is changed in the different modes. I would think HP and TQ results to all be the same result.
Andy13186
Having exhaust in quiet mode may affect the hp. I am not entirely sure if that is true on the stock active setup but I have varex active and 770 rwhp and when the valves are closed I am down 250+ hp. Wayy too much backpressure, I found this out by testing 60-130 times and went from 5's to 8s by just having the valves closed. Probably was a bad idea to test that, lucky I didnt damage anything.
engineermike
La
2018 GTPP A10
Ford doesn’t do it but you can set up drive modes to change max output. For fun, I set mine up to make the stock torque curve in normal mode but 700+ rwhp in sport and select shift. It was neat and fun for a few days then I put it back how it was…
Weeee
Utah
Tom
Mach 1, Mach E GT
Mike, did you find a way to dump the stock configuration for the different drive modes? I want to dig into the Drag Strip mode to see what it is doing.
Weeee
Utah
Tom
Mach 1, Mach E GT
I believe the drive mode selection is a set of instructions to different modules in the car to change their configuration. I want to learn what exactly the Drag Strip drive mode instructs other modules to do—for example, the shift calibration changes. You posted a couple of years ago that you had written changes to the drive modes, so I'm assuming that you found a way to read the stock configuration.
engineermike
La
2018 GTPP A10
I can read and write what’s in the Pcm, so I can tell you what the different modes do to throttle response, active exhaust, burbles, shift points, and shift firmness. The modes also tell steering, magnaride, and tc what to do and I think others have documented this in charts in the forum.
