kz
- Oct 26, 2014
- West Chester, OH
- Mustangs & F150
I've been considering getting a DSC Sport controller for Magneride for a quite while, I finally got the chance to use a borrowed one for a bit and now own one so though I'd write something for those that might be interested in it.
For disclosure - I am not a suspension setup expert by any means, I know some of the basics and that's all.
DSC Sport (for those than don't know) is an aftermarket module that fully replaces stock VDM (Vehicle Dynamics Module) on Magneride equipped cars - it's fully plug and play (you unbolt and disconnect stock unit and replace it with the DSC one, takes about 5 minutes) - they're available for GT / Ecoboosts (even though their website doesn't state so) / GT350 and GT500 (as well as Porsches, VW/Audis, Nissan GTR and probably few more cars).
They do come with preloaded maps for all three driving modes as well as with the software that offers tunability of the dampers.
Few things to note - on GT/Ecoboosts, drive modes are tied to suspension modes - so if you like Normal mode throttle mapping, you're forced to use "Normal" (soft) suspension mode and there is no way around in a stock car (GT350s have all these separated - you can change suspension map independently as far as I know) - this always was in my opinion a limitation on GT/Ecoboost cars. DSC allows you to load any calibration under Normal / Sport / Track mode, so you can tie suspension mode of your liking with throttle mapping of your liking without tuning the PCM/BCM (wherever throttle mapping sits) - this module doesn't really make any permanent changes to the car (if anyone is concerned about warranty).
Now, what I described above is only a minor tunability convenience - what it really allows you to do is tune the way shocks will behave they way you want using their software. Starting with pure damping force calibration in absolute value of the current going to the shock (which by default is linear but you can make it whatever you want in discrete steps (so no curve like equations but doubt anyone would need it), then go to G map (lateral / longitudinal acceleration 2-dimensional map), acceleration (different amount of damping based on % throttle as well as set of settings for launch), speed (car speed dependent damping), braking and finally shock velocity - which to my understanding (again - not an expert) is waaaaay beyond what traditional - even triple adjustable dampers - offer.
I had a chance to drive the car using DSC Sport and custom made maps created by @TeeLew - who was kind enough to make them available to me - during the event over July4th weekend. I can tell you that this has completely transformed the way car handled - responsiveness and how quickly car transferred load during transitions (slaloms / turns) was much much improved over stock controller with Magneride Handling Pack (which likely is a Performance Pack 2) calibration.
It also was very apparently better at putting power down at corner exit.
DSC Controller with appropriate maps is probably single largest handling upgrade that someone that wants better handling (autocross, road course especially) can do to a Magneride car (aside from obvious things like tires).
Now the question I've had is whether the DSC maps that the controller comes with are better than stock Ford maps - I'd say that they are, especially in Sport / Track mode, where they used more damping then. Comfort (Normal mode one) seems a little underdamped to me but I haven't spend much time driving on it.
Hope this is helpful, I'll add more when I spend more time using the controller.
