DRL Lighting Issue - DRLs go off when engine is running.
Iceman27
Uk
David
Mustang 2016
HI All,
ive got a strange issue with DRLs by when the engine starts and runs the DRLs go off. they are working as in when i open the car with the remote the DRLS trun of as they should the side lights work ok all with the engine off.
but as i say with the engine running the DRLs go off even then i set swtich back to side lights,
any ideas?
Skye
≈39N
"Skye" Mach1 N2144
Are they working while out on a drive?
I read the Owner's Manual, page 82. One of the conditions required for the feature to work is, "3. The transmission is not in park (P) for vehicles with automatic transmissions or you release the parking brake for vehicles with manual transmissions."
It also appears the feature might, might, be turned on and off using the Informational Display (large screen), if equipped.
"Switch the daytime running lamps on or off using the information display. See General Information (page 109).
The daytime running lamps turn on when:
1. The lamps are on in the information display.
2. You switch the ignition on.
4. The lighting control is in the autolamps position..."
Iceman27
Uk
David
Mustang 2016
Hi Skye,
thanks for comming back so quick,
no the DRLS are out completley when driving
my Pony is a Manual 2016 . the light switch is set to auto. when i stop the car and the engine goes off i have to move the swtich to the off Position and then back on light a soft reset.
could be a wireing issue maybe ?
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
Did you (or anyone) do something right before this happened? Or has it always been this way?
Iceman27
Uk
David
Mustang 2016
i did have a broken xenon bulb replaced on the headlight. i dont thnk that would of cause any issues. but you never know ....
Skye
≈39N
"Skye" Mach1 N2144
Electronics, especially now, can be touchy.
Aside from ensuring things were installed correctly (no damage during replacement) and items were all securely fastened...
Are these Ford OEM bulbs? From Ford dealer or their site? The correct spec? Are they third-party bulbs, made by someone else, possibly not the correct intensity or design?
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
I see that you are in the UK, it's possible that the daytime running lights are not programmed to be on due to the lighting laws in the UK.
DansFLHTI
canada
2016 GT, 24 Tacoma, 14 HD SG.
On my 2016 GT the drls are the lower fog lights.
raptor17GT
Scotland
Mustang GT Manual 2017 - now sold ☹
UK pre facelift models the DRL is piggybacked with the fog lights not the tribars. If you have the lights to manual do the DRL's stay on ?
Crew4991
Crew
I would take a peek at the connector assembly. You can either open your hood and remove the plastic radiator cover or remove your wheel and pull back the fender liner. It would be that a connector was never plugged back in when the headlight bulb was replaced.
Iceman27
Uk
David
Mustang 2016
Hi Rod,
My Mustang is a 2016 UK Version so it did not have the tri-bar LED, so i bought a set of US headlights with the LED Board inside etc etc. ive connected it up
the ballest are 35W now and now the UK 25W so abit brighter :-)
Green from TRI_BAR Led goes the old DRL from the Fog lamp
Yellow Goes the the Side lights (parkLights)
all come on as they shuold apart from when i start the engine up.
ive since found out the the the System has a detect on if it dectects a higher pull on the system them will go off.
the system is different to the US version of the car
so thats what in thinking. there must be somthing in forscan to may be program it.
if anyone know how to prgram it in Forscan that would be a great help
other than that ile need to test it again but remove it from the DRL FOG connecter will keep you posted on that
Iceman27
Uk
David
Mustang 2016
Yeah All connectors are all good
Iceman27
Uk
David
Mustang 2016
yes tried that they come on as they should but as i say go off as soon as i start the engine
ORRadtech
Atlanta, Georgia
Did they work the way you want before the bulb replacement?
If yes, review everything disturbed for the bulb replacement.
To troubleshoot I'd unplug them from the fog light and see if there's voltage at that connection with the engine running and go from there.
raptor17GT
Scotland
I forgot you'd changed the headlights for US versions so aye more that a bit different from our crappy pre facelift option :sunglasses:
