Drain fuel tank ?
Racer57
East Central Illinois
2025 810 hp Shelby & 1970 Cuda 383cu Tremec 5 speed.
My GT350 won't be sitting long enough for this to apply, but was wondering...................Shelby says to "Drain and replace the fuel prior to operation if the fuel in the vehicle is 6 months old or more."
Does anyone actually do this and does the tank have an easily accessible drain plug ?
robvas
MI
2011 GT
Pop the lower back seat out and you have access to the tank
You may be able to get a 'fuel drain tune' from your tuner as well
engineermike
La
2018 GTPP A10
The problem with fuel drain tunes is they only drain half the tank.
John S
Novi, Michigan
2022 Mach 1 HP
Please elaborate, If the pump is running with a "fuel drain" tune or a physical jumper on the FPDM harness connector, why wouldn't the venturi siphon drain the passenger side and empty both sides just as it would during normal driving? Thanks.
engineermike
La
2018 GTPP A10
The venturi siphon requires backpressure to generate a flow. In other words, if you disconnect the fuel line from the rail and allow it to dump in a bucket, there would be insufficient backpressure generated, so there wouldn't be enough flow through the .016" hole in the venturi to draw fuel over from the passenger's side saddle.
honeybadger
Just don't care
COTA
Kevin
GT350s have dual pumps. Not an issue here
honeybadger
Just don't care
COTA
Kevin
GT350 and 500 both rely on the venturi to pull fuel over from the PS saddle.
Nope. they have a fuel pump in each saddle.
I used a fuel drain tune all the time when I had OEM tank. it would get all but the last .5-.75 gallon out
engineermike
La
2018 GTPP A10
GT350 (and 500) have 2 pumps in the bucket on the driver's side. The passenger's side is just a fuel level sensor and the inlet for the venturi line, but there is no pump on the passenger's side. The 500 is a little more elaborate because they move the entire venturi to the passenger's side and supply fuel to it from the [driver's side] pump discharge. I know Ford calls the PS module a fuel pump, but there is no pump there.
honeybadger
Just don't care
COTA
Kevin
huh - no shit. I guess I should've pulled the passenger side hat before I opened my mouth.
I never did have a problem emptying the tank with a fuel drain tune - but maybe others do
Racer57
Racer57
What the hell is a “fuel drain tune” ?!?! :).
