door jamb wet
dirtwarrior
kentucky
Joe
2015 3.7 mustang
Is the bottom of door jamb suppose to get wet in the rain? How do I stop it from getting wet?
Interceptor
Daily Driver
Low country South Carolina
2019 California Special A10
Might want to check in at the convertible section. They are always talking about leaks
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Depends on which section you're talking about. The part with the Mustang plaque should be sealed off. The lower section above the rocker panel is a water drain, so any time water drains around the door that section will get wet.
Rapid Red
Woodstock GA
Greg
Exactly wash the car open the door.....
Torched10
Atlanta
Bob
Go to car wash and sit in car to see where it's coming in.i had a car
That was leaking water,thru the driver a pillar and spotted it that way
Rapid Red
Woodstock GA
Greg
I'm talking below the sill, as Ryan pointed out.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
The stickers in front of door are intact.
The water is coming in low. I could not find it.
There is a body shop in my town with a leak specialist.
Going there next.
You have quite a few threads on here pertaining to your water leak concerns.
When you are referring to the door jamb, are you referring to when the door is open and water is laying on the top of the rocker? Can you provide pics?
The doors have drainage holes in the bottoms of them to allow rain water or any water for that matter to drain. The water will drain from the door onto the rocker that is directly under the door. It should NOT be dumping water to the interior of the car at all.
There’s many threads on here about water accumulation inside the vehicle on the front floors (and some rear). In many instances the water intrusion is caused by missing seals on the A-pillar, bad window weather seals, clogged drainage holes at bottoms of doors, or poor seam sealer or welding of the A-pillars behind/under the windshield.
If it’s a convertible, check this thread:
https://www.mustang6g.com/forums/threads/my-convertible-leaks-in-heavy-rain.104545/
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
Car going into shop tomorrow morning to find where the leak is coming from.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
They found a possible leak, On the B pillar is a small seal. Simple piece of rubber Ford wants 180$ for. We will try to glue it since it is still in one piece. I will replace it when the price comes down. 2014 the price is 29.95 go figure
Rapid Red
Woodstock GA
Greg
LOL
rhexis
Philly burbs
2019 Audi S4, 2020 Mustang GT
last week I paid 25 bucks for 4 battery cover clips and I thought I got ripped off. 180 for some door gasket is nuts.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
It is about 4 inches long. I will try to glue it and if that doesn't work gulp I pay 180 for it
