stoli
Fat Guy Racing
- Sep 18, 2014
- Lakeland, FL
- John
- '15 Black GT/PP
Lol - touché.Flights anywhere over long distance make an arc...period lol
What cultures will be conflicted and what will make this conflict so much larger in the next six months?I am seeing a cultural conflict headed over the horizon and I suspect this issue will be huge by the middle of 2016.
Examples?There exists a genuine movement which does reveal countless amounts of coincidences that lend to the belief that the "surface" that we humans live upon is not shaped as what is described in the current textbooks.
See "great-gircle distance", aka the shortest path between two points on a sphereThere is other evidence out there, such that when you look up plane routes which airlines use to travel from one continent to the next, and they are going from the southern tips of these continents (cities located in the southern hemisphere)...it can be noted that the flights are not traveling at all in a straight line from one city to the other one. Instead, the flight path goes in a very unusual direction such that it looks like the flight just added an extra 10,000 miles of distance which does not look needed at all if you observe the two cities on a physical globe, like a globe you see in a classroom. (check this yourself and use cities such as Santiago Chile, or Perth, Australia.)
Why?This issue is going to become more and more pronounced in the coming years.
As a genuine point of curiosity, what is your education and professional background?I am educated and I am very open minded to be presented with actual facts and measurements and information that looks either curious looking and/or credible looking, and I simply am looking for what seems truthful and accurate.
As I think others pointed out, there is the ISS. Decades ago there was SkyLab. How would you propose we install a camera on the moon and why?I have always wondered why we do not have any Probe in space which sends us continuous live feed of the earth, so we can watch and see the rotation of earth in real time. I am also curious why there is no live feed being sent for us from a moon-mounted camera station.
Is there a single piece of physical evidence you can cite?The flat earth movement seems to have a gigantic amount of material that to me looks very plausible such that when someone tries to "debunk" some of the data, you end up debunking it only with info that you "assume" is true because that is what you were told your whole life. This flat earth situation is huge.
Yellowragtop - I have a genuine conflict that is being taught...Stay off the internet. You will heal over time.If for any reason this data is remotely accurate then this info is in genuine conflict with what is being taught today in any textbooks.
I know enough about satellites and the physics of their orbits that tells me the earth is not flat, but round just like science proved hundreds of years ago.The flat earth movement seems to have a gigantic amount of material that to me looks very plausible such that when someone tries to "debunk" some of the data, you end up debunking it only with info that you "assume" is true because that is what you were told your whole life. This flat earth situation is huge.
LoL....I see what you did thereSince he's already over the edge he just might be on to something.![]()
