Do I need a specific wheel alignment specifications after installing steeda stop the hop kit?
ragnar392
united states
ragnar
mustang gt
I will be taking the car to the shop tomorrow to install:
Subframe support braces
Subframe bushing
Vertical links
Subframe alignment kit
Rear lower control arm spherical bearings
I know i need to do a wheel alignment afterwards but im just wondering do i need to have a specific wheel alignment after installing all of these? Or All OEM wheel alignment will still do
iwill be using my car more on drag racing
thanks
Steeda-Sergio
Valdosta, Ga
Sergio
2018 Ford Mustang Ecoboost, 2016 Jeep Grand Cherokee, 2022 Suzuki GSXS 1000 GT
Subframe bushing
Vertical links
thanks
You'll want to go to a Performance shop that will setup your alignment to the specs you request.
Most big brand places will just scan your VIN and set you to factory range, which is very wide.
Here are some alignment specs for your ride. You mentioned more for drag, but if your still driving on the street, I highly recommend sticking closer to a street alignment.
Street
Front camber -1.03 degrees on both sides (Performance and Handling Pack)
Front camber -.72 degrees on both sides (non-Performance and Handling Pack)
Caster +7.0 degrees on both sides
Front toe +0.01 degrees per side total toe of +0.02 degrees, this is toe in
Rear camber -1.5 degrees on both sides
Rear toe +0.115 degrees per side, total toe of +0.23 degrees, this is toe in
DRAG
This is drag race only.
Front camber -0.75 degrees, must be even on both sides.
Caster +7.0 (+/- .25 degrees), must be even on both sides.
Front toe +0.01 per side, total toe +0.02. This toe in.
Rear camber -0.5 degrees (+/- .25 degrees), must be even on both sides.
Rear toe +0.12 degree, must be even on both sides. This toe in.
If you need help placing and order or have some more question, I can be reached at EXT 2170 and [email protected]!
