Do high air flow air filters let in more dirt?
Cyberbill
Bill
2019 Premium Gt Convertible
Don’t want a Cold Air Intake, so I was looking at am AFE dry drop in or K&N dry drop in air filter, that are supposed to be better then stock…With more air going thru, doesn’t that mean the possibility of more dirt getting through.
Thanks
Grandpa Bill
Austin, Tx
I'm not sure about the aftermarket hi-flow direct drop ins if there is an pre-filter that can be used - but with the aftermarket conical filters, there is a pre-filter sleeve that goes over the filter.
That pre-filter material prevents any micro dirt from getting past the filter pleating. It will not restrict air flow either and actually keeps the pleats much cleaner, resulting in less maintenance.
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
Thanks
Grandpa Bill
Austin, Tx
Typically, high flow air filters are engineered to trap dirt based upon a longer, more complex pathway for a particle to get through the bed and less upon the bed pore size. The idea is that if a micro-particle impacts the filter bed, it will stick and go no further. Oiled filters substantially enhance this stickiness and become somewhat more effective as they load up with dirt, to a point that they must be cleaned. The pre-filters actually prevent larger material (grass, etc.) from reaching the filter bed, but allow smaller particles (and air) through. I run oiled K&Ns on all of my vehicles. My Fusion hybrid tells me when its time to clean it by a 5-8 mpg drop in fuel efficiency that's restored upon cleaning. (A Fusion hybrid should consistently provide right about 40 mpg if maintained and driven correctly.)
junits15
MA
Justin
2019 Mustang GT
Short answer is: not if you do it right
the long answer:
It depends, if you want high flow you need to either use less filter material or use a physically larger filter.
cheap filters just let in more material, good filters let in just enough additional material to not harm the motor.
AEM/K&N dryflow filters are my favorite as they flow more than stock while maintaining good filtration and don’t use oil, so there’s minimal risk to the MAF.
At the end of the day though, unless you’re making extra power you’ll be fine with the stock filter
Cyberbill
Cyberbill
Bill
Whow! It looks like Puralator or WIX FOR Grandpa Bill
Thanks Guys
