DIY: Spark Plug Removal [2.3EB]
Juben
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
I've tried NGK, Denso, and Brisk. I like the NGKs the best. The Densos are good but appear to wear really fast.
To decrease the gap, it'd lightly tap them on a block of wood. You'll get a feel for it. Gap them to 0.026 too.
As far as time goes, probably about thirty minutes. It's not hard at all.
Sent from my XT1095 using Tapatalk
juan_tony1
North Carolina
Juan
ECO DIB TANG
Ngk 6510
ryant601
'16 GT - Black Accent Package
The Densos were pregapped at 0.28 I think, which is a nice selling point, but there's not much to closing the gap on the NGK's. I'm happy with mine.
chadhtx40
Frisco
2015 Ecoboost Premium PP Magnetic Metalli
So in a way it's pretty much fool proof
Take the cover off, unscrew the coils, pop out old spark plugs, and most likely replace with NGK - I do have a manual torque wrench. The only action it's seen is the wife using it to beat me up with (kidding) but what torque would I use to install the NGK spark plugs?
Thanks,
Chad
Juben
Juben
Chattanooga, TN
Justin
Thanks,
Chad
I install the plugs hand tight and then give them an 1/8 of a turn. That gets them real good and snug but doesn't overtighten them.
therealdannye
President of Capitol S550
DMV
2016 Deadpool 5.0
Same as I did for mine. I left my socket on just the extension and hand tightened until it got firm, then gave it that 1/8th twist with the handle attached. Been runnin super smooth for like... 500 miles?
Idk, my dad's been a long-time grease monkey and insisted that he hasn't had anything weird happen from not using a torque wrench. Maybe he's right.
OySmallFry@SCS
Houston, TX
SpaceCitySpyLLC
Turbo
chadhtx40
Frisco
Quick question. My plugs came in this afternoon. Plan on putting in the NGK spark plugs tomorrow. How easy/hard is it to just get the coil packs out once you removed the bolts. Any magic to that? I want to make sure I don't put too much pressure pulling them out.
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
Once the bolts are removed you can just yank them out. No magic
Brad
Owner
WA
Tesla Model S - Big Turbo EB
They come right off. Under the coil pack is a big rubber stopper, pulling them out should be no problem.
chadhtx40
Frisco
Thanks guys. First time so I wanted to dot my i's and cross my t's before I get started. Sounds simple enough. Great forum and people on here. I will get started in the morning
Brad
Owner
WA
Just make sure you have a spark plug socket with the rubber in it.
chadhtx40
Frisco
Got that covered - Thank you Brad for the heads up
chadhtx40
Frisco
Sparks installed - To close the gaps I used the suggestion of tapping the ends on a piece of wood. Went in really easily as you guys stated
Thanks,
Chad
beefcake
Bethel
2018 Ford Mustang
we really like the brisks, same thing we run in our coyote cars, the nice thing about the brisk, if you would lose a tip for some reason
it will melt before having a chance to destroy the cylinder
part # is rr14ys
if your a race only application, they do make an rr14s as well, although I doubt too many of these are race only
