Disappointing dyno numbers
Whipple SC
Fresno
Also I suppose it is worth asking how long ago you sent the ECU in for the tune? Just so we can gauge how recent of a tune you have.
Its a Lund tune, not ours. Its probably grabbing the brake.
z06psi
Evans, GA.
Andrew
The pot stirrer
Make sure to run 4th gear.
Make sure to disconnect front wheel speed sensor to disable ABS system. The 2015's consistently grab the rear brakes on the chassis dyno and its hard to tell when in the vehicle testing.
See. Differing responses on how to run.
Same say the AdvanceTrac will kick in with braking and timing. Others say it doesn't.
Same say 5th some say 4th cause of the 1:1 or the speed limiter.
WTF? Can we all get on the same page? LOL
Not pointed at Whipple directly but this thread alone has different responses.
Whipple SC
Fresno
Correct but I can tell you, from our testing, that's what we do.
4th and 5th gear will yield nearly identical HP, but 5th shows more peak torque on Dyno Jets. 5th is 1:1 but also gets near 190mph with the 7500rpm limit which I don't feel is overly safe.
I don't care what you do with advanetrac, traction control, the ABS system is on its own module, it will at times grab the rear brake and make horrible power. The brakes will glow red. While it does not do this all the time, its simple to just disconnect the speed sensor each time you dyno and reconnect when your done, eliminates any issue.
Another note, everyone should stop measuring air fuel after the cat's, its not accurate. Either weld a bung before the cats or read the stock wide band sensors.
z06psi
Evans, GA.
Andrew
The pot stirrer
Roger. Maybe there needs to be a guide or a standard so we are at least all setting up the same. I know dynos vary by brand or even age. Maybe it is just my military side coming out.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
I just pull the 50A fuse. It stays out, actually.
phunk
United States
'15 GT-PP
Travis@boostworks
Katy, TX
www.boostworks.com
2015 Mustang GT
Advance trac and pulling fuses doesnt matter on the dyno, within 5 seconds of the rear tires spinning with the front stationary, all those systems default and shut down. I never did any of that on the dyno.
5th gear wont work, gotta use 4th otherwise the speed limiter kicks in. Which I wonder if was his problem with limiting at 6000?
Still should have been making like 570 like he was thinking even with stopping at 6000rpm... but Lund might not tune as aggressively for 93 as the Whipple house tune.
We've seen advancetrac hold the brakes throughout an entire pull..
phunk
United States
'15 GT-PP
strange... mine shuts off and lights up the dash within a few seconds on the dyno. Only dyno'd it 3 times so far, maybe 25 collective pulls... so I havent seen it all yet. Just havent encountered that.
z06psi
Evans, GA.
Andrew
The pot stirrer
Kryckter
2015 GT
LMFAO. I was also told Fuse 62. Now 50? Pull both?
Fuse 62 works for me. I forget what vendor told me about the one. Its a small 5 amp fuse I think. It shows everything off in my gauges as well...
Travis@boostworks
Katy, TX
www.boostworks.com
2015 Mustang GT
Manual or auto? Auto seems to do it more.
