Daytona Alignment Specs?
GJarrett
Bradenton, FL
Gerald
2017 EcoBoost Premium
I'm primarily wondering about camber. Considering the amount of time and speed spent on the high banked ovals, would it be preferable to run a little less aggressive camber setting to put more tread on the ground on the oval (I'm thinking -2.2ish)? Or do you still run aggressive camber settings for the infield at the expense of running on more inside tread on the oval? Or am I overthinking this?
Dana Pants
Burlington MA
Dana
2018 GT PP1
Relativistic quantum mechanics tells us the car and the tires do not know they are on a banked turn. How's that for overthinking?
I wouldn't assume my car needs less camber because of a bank. I would assume my G forces and speed go up.
GJarrett
Bradenton, FL
Gerald
Thanks for your reply. I guess I may have slightly miss-worded my concern; the oval also has level sections and I will be going faster than I ever have. I thought maybe I need all the tread on the ground I can get instead of running that fast on the inside tread with aggressive camber settings. I now assume I am overthinking it :)
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I can't imagine overthinking anything when it comes to Daytona. Keep trying to get some reliable numbers from someone, but also be willing to hyper-focus on the tires every session and make adjustments as necessary.
Temperatures across the tread width are mandatory IMO.
GJarrett
Bradenton, FL
Gerald
Thanks Philip. I read your advice somewhere else to shoot for a 15 degree delta in temp across the tread. I've got a regular cheapo infrared temp gun and will see if it can focus small enough to take separate readings on inside and outside. If so, I suppose I'll have the answer to my camber question after my first session.
GTP
Deutsche Pony
Indy
Philip
I use an IR gun and I think it's good enough for my purpose. The delta is to insure a little more wear on the inside, plus it is always in contact, e.g. on the straightaways.
I just started running Cup 2s and I achieved the desired delta. I hesitate to say this, for fear of getting flamed by other experts, but for now I have been running high pressures, too - in the low 40's. I still had terrific grip, got the proper temp delta, and wore 2mm tread for the 2 day event. I got a point-by from a GT350 and slowly pulled away from a GT500.
Eventually I will post some tips about how I easily switch between street and track front camber/toe.
GJarrett
Bradenton, FL
Gerald
I will be VERY interested in learning this. :)
