Mikepol2
- Jul 17, 2018
- Pittsburgh, PA
- Mike
- 2021 Mach 1, 2019 Ram 1500
I was researching Cup 2 alternatives and found examples of other Michelin tires (e.g. Super Sports) that also cracked under cold temperatures. So I emailed Michelin and asked them directly what the temperature limitations of the Mach 1-specific Cup 2's are, and if the Pilot Sport 4S would be a reasonable cold weather alternative. Their response:
Michelin Ultra-High Performance (UHP) Sport Summer tires use tread compounds that are optimized for maximum dry and damp grip in temperate conditions. As the temperature of the compound nears freezing, the grip level of the tire begins to degrade. Michelin does not recommend using UHP Sport Summer tires when tire temperatures drop below 40°F or on snow and ice. At tire temperatures below 20°F Michelin UHP Sport Summer tires may develop surface cracks in the upper sidewall and tread area if flexed. Do not use, roll, or drop UHP Sport Summer tires with temperatures below 20°F. If the tires have been cooled to 20°F or less, let them warm up in a heated space to at least 40°F before being installed or moving a vehicle on which they are installed. Do not apply heat or blow heated air directly on the tires.
Although they don't specifically use the term "ultra-high performance" on their website, the Pilot series web page address is "ultra-high-performance-sport". The summer UHP tires listed on that page are the Cup 2, PS4S, Super Sport, Sport PS2, Sport 4, Sport 3, and Exalto PE2. Therefore it appears that any of these tires could crack at temps below 20F, which is backed up by pics I have seen online of Super Sports and of course Cup 2's with freeze cracks.
Therefore it sounds like replacing the Cup 2's with PS4S really doesn't get you any relief as far as cold temps. So if you have some disposable income to spend on a set of winter wheels and tires, that's probably the best option. If not, park it for the winter. If the garage gets below 20F, get the car up on jack stands so the weight isn't on the tires. Not the answer I was hoping for but wanted to pass this along to everyone.
