Coolant orange, what do I mix it with?
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
So I the opg and cs, and my coolant got a bit of oil and dirt in it, so I want new coolant, I see the orange is recommended, but I cant find any thats mixed already, so what do I mix it with? Does distilled water do the trick?
Demon Coyote
Naperville, IL
2015 Mustang GT
When I installed my Paxton kit and had to drain the system. I filled it up with half orange and half distilled. I would take water bottles and fill them up with half orange and half distilled water, mix them up, and then power them into the tank in batches to get as close to the 50/50 mix as I could.
v8ter
v8ter
Typing...
EL PASO , TX
That sounds good!! Gona do that
blown302
ct
1987 mustang gt/2004 svt cobra/2016 GT PP
Ford sells pre mixed orange pat no. vc3dilb.
ElAviator72
Canby, OR
Brent
2016 Ecoboost PP Deep Impact Blue (base 100A car)
Same spec as Dex-cool...I've topped off my own coolant recovery tank with Dex-cool and had no ill effects ;) Always used tap water for the H2O portion. You can buy pre-mixed Dex-cool and water at O'Reilly's if you don't want to worry about doing the mixing yourself.
v8ter
v8ter
Typing...
EL PASO , TX
Im gona mix it woth distilled water. Hows the process ? Just pour it into the reservoir until its full? How do I get the air out?
Bartly
Out West
2016 Mustang GT
Color means nothing, there are probably 3 different types of antifreeze that are orange. It's the chemical type that matters. There's OAT, HOAT and one or two more. Not sure which type ford uses, but stick with that, unless doing a complete flush, then you could probably get away with any of them. Also, never use tap water, only distilled, unless you want stuff growing in your cooling system.
v8ter
v8ter
Typing...
EL PASO , TX
ScottsGT
Lake Wateree, SC
Scott
2015 GT, DIB
What's the life on this orange stuff? I'm use to doing a flush every two years with the regular Prestone yellow. Just about to hit two years with my GT and I'm wondering about flush and fill.
v8ter
v8ter
Typing...
EL PASO , TX
It should last 100k or 5years
v8ter
v8ter
Typing...
EL PASO , TX
I see that the coolant capacity is 13.6quarts on the 5.0,mine is full and stays full with 8 quarts, I drove around, head and coolant temperature is normal at 190 head 208f, and I squeezed the top and bottom radiator hose and seem like no air is trapped. Since I did the opg,I had the water pump removed and the radiator drained, would there be so much coolant still somewhere?
Dragster
2015 GT PP
The Ford service manual says that less than 80% of the coolant is recoverable with the engine still in, so that will account for some of the difference. Also, you can buy the Ford recommended Motorcraft coolant on Amazon for a good price.
Jay-rod427
Kansas
2016 GT C/S
I bought a gallon of the concentrate yesterday at local ford dealer for $20. The CORRECT coolant. Don't listen to anyone saying use dexcool, or any water but distilled. Unless you don't plan on keeping your car very long.
