GTP
Deutsche Pony
- May 27, 2015
- Indy
- Website
- www.BambergAudio.com
- Philip
- 2019 GT PP1 A10 Outrageous Orange HPDE mods
Made me a cradle lowering kit.
I cut up a 1 meter length of 14mmx2.0 allthread from McMaster into 4 lengths of 10" each. I used an old Workmate to hold the rods and a battery powered saw. I ground the ends real nice. I chose the lowest strength steel because these are only used as a temporary tool.I I sourced the nuts and washers locally to save overall cost.
Took under an hour.
I plan to use these to lower the cradle enough to get the front diff insert bolts installed. Another benefit is that the cradle will raise with each bolt hole lined up when replacing the blue bolts.
Took under an hour.
