Consensus gearbox fluid and diff fluid being used.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
@honeybadger ...interesting you're using that one. That's not the one that's a MERCON LV fluid. What made you chose that one? And it's working great for ya?
@Lurker_350 ...your second link was to engine oil, but yes, that's correct oil As for the tranny fluid, the Amsoil fluid that meets MERCON LV as per the owners manual is this one....
https://www.amsoil.com/shop/by-prod...c-automatic-transmission-fluid/?code=ATLPK-EA
Was the closest match to the RP Synchromax I had been using. It's still early in my testing, so not a lot of data. For me, the Mercon LV stuff is always too thin and gets a bit burnt up with track use. The Syncromax/Mesh types handle the heat better but are still thin enough to not cause problems with the tight tolerances in the trans.
Lurker_350
TX
2016 GT350 - Tech
@galaxy I think my link should be to the entire products page, but yours is more clear.
galaxy
St Louis
'17 GT350
Aaaahhh, gotcha. Interesting enough, I never looked before but noticed on the fluid you're using, it calls out a lot of the Tremec tranny's anyways.
