P0010 - "A" Camshaft Position Actuator Circuit (Bank 1)Had some codes pop up after I got a clutch, driveshaft, and axles installed. Did a crank relearn and deleted the codes and they keep coming up. Fuses look good. Any help would be great!! Some of the codes are p0010, p0013, p0020, p0023, p0135, p0443
I did some more digging around on the forum and found out that fuse #40 in the engine bay fusebox is related to all the CEL codes that were thrown. Now the problem is after installing a new fuse, it instantly popped... having my guy check the wires near the back of the engine to see if anything got pinched during the transmission re-installation.Did you do an erase keep alive memory before or after the crank relearn?
I am having the same issues. Did you ever get the problem resolved?I did some more digging around on the forum and found out that fuse #40 in the engine bay fusebox is related to all the CEL codes that were thrown. Now the problem is after installing a new fuse, it instantly popped... having my guy check the wires near the back of the engine to see if anything got pinched during the transmission re-installation.
Heres the link to the post I found:
https://www.mustang6g.com/forums/threads/new-whipple-a-few-issues.116538/#post-2449163
99% chance a wire is smashed, cut, brokeI am having the same issues. Did you ever get the problem resolved?
Any clue where I should look? Or wires that tend to go bad more often?99% chance a wire is smashed, cut, broke
Did you do any work to the car?Any clue where I should look? Or wires that tend to go bad more often?
Installed 2018 ported IM and JLT CAI.Did you do any work to the car?
Codes?Installed 2018 ported IM and JLT CAI.
P0010, P0013, P0020, P0023, P0135, P0141, P155, P0161, P0443, P0446Codes?
Every time I have a lot of codes that make no sense it turns out to be a ground wire. I would look behind the manifold and make sure all wires are connected but definitely check the ground wires and strapsP0010, P0013, P0020, P0023, P0135, P0141, P155, P0161, P0443, P0446
