Clutch poll lets gets some input
Let’s get some input on these choices. I’m doing some fall shopping
  • Total voters
Justgonna send it
NC
Ty
2019 GT 6spd ess G3 kit 120mm pulley , wendgerd tune & 2020 hpp eco
So I have hit my 30k mileage mark and problems are starting to show like lockout in second gear in higher rpm 5k and up. So it time to replace.
Zrussian13
Phoenix
How do you use your gt? The rst and rtx are good for different reasons. Not sure I'd consider the other two options. Personally I'd add the lpxhd to the list too if it were me.
Justgonna send it
Justgonna send it
NC
Ty
I use it for mostly weekend driving. Hard pulls and speed shifts at times.
I looked at the lpxhd but I have seen some bad reviews. So im a little gun shy of this brand. I know it probably a rebadged McLeod with some little changes. So I’m just wondering if these changes are what’s causing all the bad reviews.
Zrussian13
Phoenix
I had some issues with mine initially but now it shifts good. If you search there are issues with basically every aftermarket option out there. Mcleod, mantic and even ram. I did some looking thinking maybe I spend a little more next time to avoid any issues but doesn't seem to help. I've decided your rolling the dice regardless which clutch you choose. I'll see how long my lpxhd last and then decide whether I try a different clutch next time. I've got about 23k miles so far.
Justgonna send it
Justgonna send it
NC
Ty
Have u had to 4th gear chatter. I have seen that issue the most
J17GT
IL
2017 Mustang GT PP
That ‘chatter’ is not the clutch. It’s called ‘gear rollover’ and you’re hearing noise from the transmission. You’ll experience that on any solid hub clutch setup.
Justgonna send it
Justgonna send it
NC
Ty
Thank you sir I didn’t know that
Justgonna send it
Justgonna send it
NC
Ty
I like exedy. But Everywhere I looked I only saw single disc set up and I need twin Disc.
Justgonna send it
Justgonna send it
NC
Ty
Tru. Have never been that low in 4th anyways. But online review can make or break a deal. And this is a expensive dice roll.
Justgonna send it
Justgonna send it
NC
Ty
bump
