Clutch/brake pedal assembly removal
misterMKiii
South
Michael
2017 GT350
tevaburns
Clawson, MI
Tiberius
2015 GT Premium PP
Has anyone been able to replace the clutch pedal arm while leaving the assembly in the car? Is that possible?
OrangeCrush5.0
Kenosha, WI
Shawn
2016 Mustang GT Premium
it’s not possible to replace it in the car.
It’s also not possible to repair the cracked welds in the car. The bushing is plastic, you need to weld the arm to repair it, it’ll melt the bushing.
I would highly suggest throwing a nice weld on your cracked pedals rather than buying a new one. The new one will fail the same way as the old one did, that one weld is just not sufficient.
Elp_jc
None
How easy is to remove the bushing, to weld the arm properly? That's probably the way to go, since a new pedal would be equally bad. It obviously doesn't make sense to do all of that charade just as a precautionary measure, but once it fails, and it needs to get removed, it could just get fixed properly, no?
OrangeCrush5.0
Kenosha, WI
Shawn
The bushing slides right out. I sand blasted around the area and welded all the way around instead of having the small stitch weld that was there.
Here’s the info to removing the pedal assembly for a MT82 equipped S550:
EDIT:
Also included the same for an Auto equipped S550 (even though it’s 6R80 specific, pedal assembly is the same if having the 10R80)
tevaburns
Clawson, MI
Tiberius
2015 GT Premium PP
Hey guys. What's the recommended procedure for getting this retainer off? flat-head screwdriver?
tevaburns
Clawson, MI
Tiberius
2015 GT Premium PP
I just got my clutch & brake pedals back from a local welding shop. $40 for the pair. I'm going to throw some paint on them before reinstalling. Not sure if anyone has had the welds on the brake pedal fail but I'm not taking any chances. Might as well reinforce both.
If you are in the Detroit area: All Welding & Fabricating 1882 Woodslee Dr, Troy, MI 48083
GT Pony
Pacific NW
Looks to be excellent welding work. Too bad Ford can't do it right from the start. 😖
