misterMKiii
Thanks very much!You do not need to drain it. If you have any other questions let me know, I’ll keep an eye on the thread. Good luck!
Thanks as well, really good info. Starting to realize how poor the build quality is on some of these components. I am just a tick under 24k miles and it's already starting to fail.Just popping this thread here too, as it has a lot of info regarding the failed clutch pedal assembly:
https://www.mustang6g.com/forums/th...-manual-cars-check-your-clutch-pedals.155008/
it’s not possible to replace it in the car.Has anyone been able to replace the clutch pedal arm while leaving the assembly in the car? Is that possible?
The bushing slides right out. I sand blasted around the area and welded all the way around instead of having the small stitch weld that was there.How easy is to remove the bushing, to weld the arm properly? That's probably the way to go, since a new pedal would be equally bad. It obviously doesn't make sense to do all of that charade just as a precautionary measure, but once it fails, and it needs to get removed, it could just get fixed properly, no?
Yep ... work it up as you go around so it comes off evenly.Hey guys. What's the recommended procedure for getting this retainer off? flat-head screwdriver?
Looks to be excellent welding work. Too bad Ford can't do it right from the start.I just got my clutch & brake pedals back from a local welding shop. $40 for the pair. I'm going to throw some paint on them before reinstalling. Not sure if anyone has had the welds on the brake pedal fail but I'm not taking any chances. Might as well reinforce both.
If you are in the Detroit area: All Welding & Fabricating 1882 Woodslee Dr, Troy, MI 48083
