One week and you should be good. I have Kenzo, was instructed this, and it worked completely fine.How long before you washed your car after (Ceramic Pro Light "bronze") was install? I am driving 700 miles 6 days after the install. I find out after the job was done it takes up to 3 weeks to cure.
Lee.
How often do you wash your car?You are okay to wash the car after the week.
Some IMPORTANT information ( I have 5 Coats 9H + Light )
There is no need to wax or polish the vehicle.
Keep up on it with hand washes with a good neutral soap.
DO NOT let water dry on the car. The rain is fine however (atleast here in my) there are minerals and chlorine in the water and if you was the car and do not dry it the water spots will mark the coating and will be a huge PIYA. Just make sure you completely wash and FRY the car after using hose water.
I’m 6 months in and it looks like I just got a compound wax and polish detail.
Also ceramic sport works great as a Quick detailer however it is too strong for none trained people to apply. Mix it with water and rubbing alcohol to dilute it. You can use it as a quick detailed spray for any spots between washes.
With ceramic, once a week at most. You can easily go 2-3 weeks though. My car is black and even after 90+ miles it looks like it just washed it.How often do you wash your car?
When you say 50/50 mix, do you still dilute with distilled water or are you talking a straight mix. ThanksLike all the “old waxes” we had a detail spray for car shows!!! Here’s what to use for that. Extra POP !! A 50/50mix of Reload and ECH2O....spray and MF wipe, You’ll love It!!
Also...look into Essence Plus....a coating on top of the ceramic used to fill in slight swirls and scratches!! Usually after a year of the Ceramic install!! I’m ready for that process now!!
