Can you disable yellow turn signal DRL?
Min Ahn
Denver, CO
Min
2019 Mustang Ecoboost Premium
I've done a full day of search but I could not find a solution to turn the yellow turn signal DRLs.
I'm not even sure if they're called the DRLs but I'm referring to those lights in the picture I attached.
There is an option to disable DRL in my digital gauge cluster settings menu, but it did nothing.
I have Forscan and OBD transmitter so it would be great if it's modifiable.
Thanks!
EDIT
The lights I was referring were Amber lights not DRL, thanks
The S550 DRL would be the white tri-bar LED lights directly above the amber signal/parking lamp assembly; this applies to all 2015-2020 S550ā€™s.
In your image, you have circled the signal/parking lamp assembly. Just curious, why would you want to disable the park/signal lamps? In most States if you had to go through a vehicle safety inspection, the vehicle would fail for inop front signals.
This below thread has a ton of Forscan updates and info to adjust the S550 ā€œAs Builtā€ coding. I do recall seeing ā€œDRLā€ discussions in this link, so youā€™ll have to read through (itā€™s a huge thread):
https://www.mustang6g.com/forums/threads/modifying-as-built-data-guide.61773/page-141#post-2629287
robwlf
phila
rob
17 lightning blue pp LFP 670
just buy the switch back bulbs.. least they will be white till you use the turn signal
Min Ahn
Min Ahn
Denver, CO
Min
Yeah, I was not sure what to call those lights since they seem to be always on but, shoot. I never knew this would a law related matter. I just canā€™t stand these yellow lights ruining the chic/modern look of front fascia.
That would be very convenient but do you think thereā€™s such bulb for 2018-2019 s550? Unlike the previous gen, current year model seems to have multiple light bulbs inside of the light assembly. I will go check on it!
green97probe
Monongahela, PA
Jim
2018 Mustang GT, 2014 Edge
2018+ uses LEDs there.
You could tint the amber lights to make them less noticeable. The amber signal/park lamps are only on when:
1) making lane changes (L or R signals)
2) selecting only the parking lamps from the light indicator selector
3) when headlights are turned on
The DRLā€™s are on 24/7/365, unless you are able to change the As Built to turn them off.
Min Ahn
Min Ahn
Denver, CO
Min
Yeah I figured I would need to buy at least 6 to 8 Switchback LEDs if I were to change them all. But I think the light assemblies are glue sealed making it very troublesome to replace the bulbs if replaceable at all :/
I guess I will leave the headlights off and just have the DRL and Fog lamps on at night lol
Well, this is an option... there are several styles and manufacturers
Unfortunately mineā€™s a 2019 model. I think 15-17 only had one amber bulb on each side which made it very easy to replace with switchback leds.
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
I'm not sure about the '18+, but on the '15-'17s those tri-bar LEDs are not the DRLs. DRLs are something else entirely and based on the country the car was shipped to.
Gregs24
Wiltshire UK & Charente FR
Greg
Mustang V8 GT, Ford Kuga PHEV
I would have thought it must be possible to revert them to UK spec where they are direction indicators only and off unless used.
Min Ahn
Min Ahn
Denver, CO
Min
I never knew Euro standard ones are that way. Thanks for the motivation now time for some research lol
Edit: wow.. white lights looks very clean and chic
15 Stang
Glucksdadt, MS
2015 Ecoboost Convertable
How did you come to this conclusion? This is not true at all.
On my 15, the tri bar lights illuminate every time my transmission is out of park, and this is consistent with the lighting section of my owners manual.
You may select to turn this feature off by using the information display if you wish. I get a discount from my insurance company for having DRL's.
FruityJudy
South Alabama
2018 Mustang GT A10
My tri bars illuminate everytime whether DRL is on or off. My actual projector only illuminates at night or if my DRL are on.
TexasRebel
Gearshifter
2016 YZ GTPP - PP2
The three bars are classified as accent lighting as they do not fit the requirements for Daytime Running Lamps. It's not really a conclusion I came to, just something listed in the standard features. If you're getting a discount for them, great. Don't tell your insurance company they are wrong.
jbanh100
Houston
Jackie
2021 Tesla Model 3 Performance
Hoping for an update! It would make my black mustang killer. Just the tint ain't cutting it.
