Cam Timing Information
TX5OH
Nathan
2016 Mustang GT Convertible
I am thinking about doing cams. I know with the VVT the cam timing varies, but do any of y'all know what the timing events for the Gen 2? I found them for the Gen 1, but no luck in find Gen 2 specs or at least anything that confirms the Gen 1 timing events were used on the Gen 2. I know lift increased. I would like to know what centerlines and how much I can swept them. Looking at the NSR cams, about 500 rwhp seems to be the ceiling without doing ported heads. I am basing this on the dyno graphs I have seen on here and also using software to simulate my setups. However, I have found that I if I can increase the lift I can get even higher numbers. And also, it appears there is more power in going lower in valve lift than the 0.512" stock lift, but going a good bit longer on the duration, and playing with the LSA.
Below is what I have found for Gen 1. I am hoping I can find Gen 2 or confirm this works for Gen 2.
Stock Mustang GT 5.0 Coyote Cam specs:
Intake Cam:
Advertised: 263
.050": 211
Lobe Lift: .235"
Centerline (Park / Max): 139 / 89
Exhaust Cam:
Advertised: 263
.050": 211
Lobe lift: .216
Centerline (Park / Max): 123 / 73
Valve events @ Park (no adv/ret) @.050":
IVO: 33.5 ATDC
IVC: 64.5 ABDC
EVO: 48.5 BBDC
EVC: 17.5 BTDC
Total overlap (Park) @.050: -51
Valve events @ Max @.050:
IVO: 16.5 BTDC
IVC: 14.5 ABDC
EVO: 1.5 ABDC
EVC: 32.5 ATDC
Total overlap (Max) @.050: 49
TX5OH
TX5OH
Nathan
I am working on validating my setups and will come up with a cam I want to use, which may be an off the shelf one or a custom grind I design. The software over predicts slightly, but it is an older version. A buddy of mine has newer version and it is a little more accurate.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
TX5OH
TX5OH
Nathan
According to that.. The fingers are at a 2.02:1 ratio. That can't be right ? .2535 cam lift (according to the chart) times 2.02 ratio = .512" valve lift.
Most of the literature from ford gives everything in mm . 13 mm is the lift they say which is 0.5118”. It’s just probably some rounding error.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Yea was just curious. Now I know how they get such high valve lifts on relatively docile camshafts.
engineermike
La
2018 GTPP A10
The vvt timing is in the calibrations for these engines. If you have hptuners you can download various stock files and see what they do. I have the voodoo and 2018 downloaded but not the other stuff. The weird thing is that the cal commands an evo and ivc, but 0 isn’t tdc. There’s an offset elsewhere in the tune. The 2018 5.0 moves the intake cam from 20 deg advance to 24 deg retard as rpm rises. At cruise it retards both 40-50 degrees.
