Brake ducts
nastang87xx
San Diego, CA
2016 GT350 Track Pack
just a reminder to everyone, the drilled rotors are non-machineable meaning we can only buy new ones:headbonk:
My personal experience has been that if you need to machine your rotors, buy new ones anyway. Now if you just need to put some 400 grit to them to remove some caked on pad material, that's different. Big deal.
Grimace427
NoVA
2011 Mustang 5.0
I only replace brakes with new parts anyway.
bpracer
DFW
2013 FR-S, 2005 F250
My closest track is incredibly hard on brakes, so yes, I may see how easy it would be to fabricate some proper ducts to the eye of the rotor.
I'm wondering if those stock ducts are more for insurance that those R model carbon fiber wheels don't get too hot. the inside of the R wheels have a heat reflective (I assume since it's white) on the inside.
Voodooo
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
Thats what ford said it was for. Heat. That's exactly what I was thinking when I thought about making brake ducts. They can't be too cool. Same for the bearing. Extra cooling will never hurt.
bpracer
DFW
At least you have your car.... My order has not even been pulled.
I don't have a tig welder, but I could still make the pieces to be welded up. Vorschlag is just down the road from me, not sure if they would be interested in making a kit. I wonder if Watson Engineering, near you, is thinking about making a kit.
Voodooo
Voodooo
SE Michigan
Scott
American racing headers makes all the headers for Watson and all the ford cobra jet and boss r & s cars for Watson. I've made a few sets of headers before and it's time consuming. I have a tube bender and Tig welder band saw mill etc and it's still a time consuming deal.
krt22
CA
It's a constant stream of cool air, it will cool everything in the wheel well and the rotors/calipers the most since they are the two hottest things in there. Seems like you car is 85% geared towards the drag strip as well, should be zero issues for you
Mountain376
SE Michigan
'17 Camaro SS 1LE, '16 Camaro SS, '12 Mustang GT
The only thing is, with how wide the wheel/tire combo is up front and the OEM offset, you may not have a lot of room to play with to route hoses between the tire and suspension or chassis at full lock. You will likely have to either 1. squish the hose flat at some area or 2. get creative in the routing, maybe by going very in-board toward the engine bay and coming nearly straight out, perpendicular to the rotor.
krt22
CA
Or utilize what what a bunch of ford racing PhDs have already designed, modeled, and track tested?
Mountain376
SE Michigan
One thing you could do would be to remove the brake dust shields if you really feel you need some extra cooling. I think only the front has them. If you do this, I suggest keeping some type of tie rod end heat shield for durability measures of the joint long term.
Mountain376
SE Michigan
Right. I would agree with driving the car, first, and seeing if you really need additional cooling for your purposes. Just keep the brake fluid fresh and bled.
ITLRUN
HiPo Joe
Adairsville, GA
Joe
2017 GT350R HR186
Actually, they can be too cool... :frusty:
