20maxima
Yep I sent it back in the box it came in they got it within two days I had the deposit refunded by the following weekend Great simple process!So I received my Boomba short shift. Followed the video and installed it yesterday evening. It was like 95 degrees with ridiculous humidity so that was fun even in my garage. So far I really like it but I've only put a few miles on it. More driving to do today!
A couple quick points:
- there was a lot of talk about the zip tie. I previously posted that Boomba should include the zip tie because I was under the impression they were not included. Well, apparently they are included. I received a small little bag containing a zip tie and the 2 little supports you slide into the bushing. That said, they are conventional zip ties, not the low profile type, so I understand now what people were talking about. A low profile would def do a better job here.
- the install video says you will need an 18mm socket. This is for using their rental tool. I was 99% sure I had one and didn't stop to buy one on my way home. Of course...I didn't. Wouldn't you know that my largest one was a 17mm! I did, however, have a 3/4" socket and that worked perfectly. Keep that in mind if you're in the same predicament.
- the install video says you will need silicone lube spray. I had WD40. Not sure if that's silicone or not (I don't think it is) but that's what I used with no problems.
- Lastly, for those of you who have rented the tool, are you returning it in the same box that Boomba sent? Seems like it could fit in a smaller box but I wasn't sure. I did notice the prepaid label so that was nice.
And you're quite welcome! Happy to help. Hope things are starting to settle down for you guys. Do get back in the air when life allows...once an airman, always an airman.
