Blown differential or axle?
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
Jack up the back and spin the tires by hand and listen. It sounds like a halfshaft or driveshaft failure to me.
SD_GT
SD_GT
4-Banger
San Diego, CA
Nope
Red.
Local mechanic shop. I had the McLeod unit installed with a brand new OEM slave cylinder as well.
SD_GT
SD_GT
4-Banger
San Diego, CA
Nope
Red.
Car was towed to ford last night. I'd much rather it be something along those lines than a transmission or clutch. What leads you to believe that it's a half shaft or driveshaft?
rvlyssup
Vag...Gun...Stang-NUT
Palmdale...The High Desert of SoCal.
Rand
Lotsa...
Is the squeal from the front or rear? It does sound like your brakes are still engaged therefore dragging and making the noise.
Sounds to me like when you launched forward during line lock and you aborted it, the brake system did not fully disengage. From my limited knowledge of the LL feature, only the front brakes are fully applied so one care freely spin the rear wheels.
SD_GT
SD_GT
4-Banger
San Diego, CA
Nope
Red.
That was my whole initial theory, the brakes never disengaged thus why the car would barely let me creep forward after aborting the LL. As soon as the car jumped forward I let off the throttle and put the clutch down. The thing is, if the brakes were dragging, why would I be able to push the car smoothly in neutral?
rvlyssup
Rand
Lotsa...
Ah...missed that part. I've never tried LL, doubt I ever will even though I am sure it is safe to do so 110% percent. (after all, that is what the car is designed to do)
Other than the brakes dragging, something probably broke within the transmission itself. If the car coasts just fine in neutral with no noise, then it is probably not from the driveshaft back.
Hopefully the dealer gets back to you soon with some sorta good news. Good Luck & keep us posted. :cheers:
SD_GT
SD_GT
4-Banger
San Diego, CA
Nope
Red.
The odd thing is that I was able to push the car perfectly fine it first as well. That's not right. Haha
SD_GT
SD_GT
4-Banger
San Diego, CA
Nope
Red.
Just spoke to a service advisor at Kearny Pearson Ford. He said it'll be $150 inspection fee IF the failure is due to the installation of my new clutch from an independent shop. If it's something they can cover under warranty, it will be free.
SD_GT
SD_GT
4-Banger
San Diego, CA
Nope
Red.
I've got my fingers crossed hoping everything works out! I guess the transmission warranty is not voided due to the clutch since they didn't touch the internals of the transmission during the clutch swap. At least, that's my assumption.
rvlyssup
Rand
Lotsa...
Did you tell the SA about using the LL when it happened?
SD_GT
SD_GT
4-Banger
San Diego, CA
Nope
Red.
Now my question is - if I get in writing that a component failed due to the independent shop's clutch install, will I have a shot at getting the shop to warranty their work? I'm out of the 30-day warranty period at this point.
SD_GT
SD_GT
4-Banger
San Diego, CA
Nope
Red.
I was about to say...too short of a duration me thinks. Whatever broke probably would've reared its ugly head on a hard launch from a stoplight.
Amen. Now I'm anxiously awaiting the verdict. They said they had a tough time even moving the car off the tow truck. Haha
