Blown fuse
duanbo
Canada
Horse
Does anyone know which fuse is for right running twilight/turn signal. My right side running lights not turning on.
Thanks in advance
FordTechOne
Cobra
Thanks in advance
Fuses don't blow for no reason; the root cause will be a short to ground in a circuit or a high amperage draw from a faulty lamp.
Have you modified anything? If not, your best bet is to just take it to the dealer so they can diagnose the issue for you.
duanbo
Canada
Horse
I was trying to switch my switchbacks and believe I blew a fuse. My running tail lights and turn signal don't come on. Signal works find and brake lights works fine also
FordTechOne
Cobra
The lighting is controlled by a Field Effect Transistor (FET), meaning that a fault won't typically cause a fuse to blow. Instead, the module will disable the output to the lamp and set a Diagnostic Trouble Code (DTC). The DTC needs to be cleared with a scan tool in order to allow the lights to operate again.
