Billet Oil Pump Gear Set for FI
joe603
ATL
Joe
2021 GT Premium PP
Hey guys, just doing some research for my upcoming project to install an ESS kit on my 21GT. I'm going back and fourth on if I should do the work or have a shop install/test/tune for me. A reputable shop in ATL gave a decent quote for an ESS install, but mentioned adding a billet oil pump gear set and billet crank sprocket. Now the ESS install was a great price, but the gear set almost doubled it.
My question is...is it worth doing the billet gear set? Is this something a lot of FI guys do? I don't plan on going crazy with boost...probably a G3 with 120 pully and 93 tune.
daSNAK3
Cary, IL
Jake
2021 GT
You don't need them. I'd leave them as is.
And the install is easy, I would also recommend doing the install yourself, if you can use basic hand tools.
daSNAK3
Cary, IL
Jake
2021 GT
If it makes you feel any better, I run the 100mm pulley on my wonderful MT-82 and ring the car out to 7900rpm and I have made a couple whoopsies on the limiter (I don't recommend doing this though, lol)... stock engine still holding up good. Been boosted around 15,000 miles or so now.
engineermike
La
2018 GTPP A10
Seems like you don't hear about many broken opg in the last few years. It could be that it was more a gen2 weak point. The early gen3 got a fluid damper stock, but I believe mid-2019 they switched back to elastomeric. Another thing that I think is/was a problem is that tuners were raising the soft-limiter (throttle controlled) above the hard limiter (fuel cut), not fully understanding what they were doing at the time. I still run across this sometimes. Make ABSOLUTELY SURE your tuner has the fuel cut limiter set 2-300 rpm above the soft limiter.
joe603
joe603
ATL
Joe
2021 GT Premium PP
Great replies, thanks guys!! As for doing it myself, very tempting, how's the spark plug job with these engines?? Is it a shit show or pretty easy? The tuning shop quoted just over 2k for the install labor, tune and dyno.
daSNAK3
Cary, IL
Jake
2021 GT
I only had slight trouble with the back passenger side plug, but if I remember correctly I just had to piece together some extensions and swivels and it was fine after that. Spring time I get to do it over again and swap in some new ones. Not that bad at all.
I'd do the install yourself and get a tune by one of a guys that really know this platform. I've seen guys go to local shops and end up with a shitty tune and paying twice.
HKusp
Hampton, Md.
Jason
Passenger side really is the hard one. Take the battery box out and it's a straight shot. $2k for the install, tune and dyno is a great price if they know what they are doing tuning.
beefcake
Bethel
2018 Ford Mustang
same thing we tell everyone, its not required, but, if you think you may be using a tb or 2 step, or hitting the limiter at all like running it out, its good protection
https://www.beefcakeracing.com/boundary-opgcombo/
Feel Free to DM me or call with any questions.
Terry "Beefcake" Reeves
Office - 855-TBR-RACE - Cell 513-478-1965
Owner Team Beefcake - 20+ Years Experience
Deal Directly with the boss, no pushy sales guys!!!!!!!
https://www.beefcakeracing.com - Your Forced Induction Specialists
#beefcakeracing #teambeefcake
Pistol_91
Clearwater
2020 mustang GT
There was literally a thread on OPGs a few days ago on here with a poll.
joe603
joe603
ATL
Joe
2021 GT Premium PP
Ya, saw that...tons of good info for sure! For my thread, I also wanted to get opinions on the price I was quoted for the install labor/tune/dyno and didn't want to hijack that thread.
Pistol_91
Clearwater
2020 mustang GT
Good call. Pricing for that stuff seems to be a large range from what I've seen people post on here. Good luck
joe603
joe603
ATL
Joe
2021 GT Premium PP
What daSNAK3 said, you don't need them. I have the same setup, G3 120mm 93 octane. Just don't get crazy and bounce the car off the limiter and you will be fine.
Looking at the price difference between G2 and G3...wonder if a G2 with a 115mm and the G3 intercooler would work? I don't want to go much past 700 anyway.
daSNAK3
Cary, IL
Jake
2021 GT
They are going to tell you not to run the 115mm pulley on the Gen 3.. G3 will make better power and be more efficient, I’d spend the couple hundred extra and get the G3 w/ 120mm
