Best Gear with Procharger
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
315 has its own differential, 355/373 share the same differential. The housing itself is the same.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
I am running 285x19 Michelin pilot sports in the back. No tracking, this is just a fun street car. How do you like the 3.55 gears? Going from 3.15 I have to do the whole pumpkin I believe.
I love the 3.55's, but I needed Drag radials with just an E85 tune on my car (no boost) to eliminate the wheel spin. You may need to up your tire game. 10PSI of boost on E85 brought wheelspin through first, second and screeching on the 3-4 & 4-5 shifts. I went to the tall street R's, then bumped up boost to about 15#. Traction is back. going up to 16# in spring.
Stangmang
Stangmang
Massachusetts
James
2015 GT Mustang
You make more power than the OP, and also have a 10r80.
The OP's setup is the mildest boosted combo possible. Traction from a dead stop on anything short of a drag radial should be a problem now. It doesn't sound like he is trying to make hits from a dig on a regular tire. Slow roll im sure its fine. Ive ran 315, 355 and 373 with a procharger, with a 6r80 from 600whp all the way to 1300whp. Based on the OP's original post, 373 would be my recommendation.
Definitely not trying to make hits from a dig as you say. My end set up by spring will be adding headers, the ported 18 mani, bap and a 3.5 pulley to hopefully hit near 10 psi on pump. Hoping to be around 650ish wheel at that point and I don't have any intentions on going any crazier...of course that's what I said after the basic first tune.
The interest in smaller gears are really just to "feel" a bit more pep around town and also get the blower to spin up quicker along with the other mods to work with the direction on how the motor is built to work. I'm thinking to go with the 3.55 pumpkin, see how it shines and then try the 3.73s if I still think it needs it.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I tried.
Stangmang
Stangmang
Massachusetts
James
2015 GT Mustang
You did, and thank you sir for all your information! I was just trying to say that I'd have to get the 3.55 pumpkin first anyways, so I might as well see how I like it before ripping it apart to add more gear.
Thanks again
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Thanks again
You do not need to buy another housing. Just get the gear you want and corresponding differential, install that in your housing.
Stangmang
Stangmang
Massachusetts
James
2015 GT Mustang
Really, I didn't know that you could. Thanks!
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
Very happy with my Torsen equipped 3.55, A10, Procharger Stage 2 HO, with an estimated 640-650 whp.
With any set up similar to this, proper rubber is critical. I am running the Nitto 555R2's in 305, it's still spin city below 45 mph with full throttle.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Traditionally, people fear the gear. LOL
LSchicago
Illinois
Lloyd
I am not one of those. I put a 4.10 in my 73 Cutlass 455 4 speed, And told my dealer the GT he got for me must have 3.55's, because that was the highest numerically offered. Add traction, and let it rip!
Angrey
Coral Gables
2016 GT350
I'm pretty sure the 3.15 only comes compatible in the Aluminum housing. The ring and pinion sets for 331, 373, 355, 409, etc will work in the iron housing. As far as I know they're not interchangeable between the aluminum (3.15) and the iron housing (331 and up).
andrewtac
TX
mark
F250. 2020 GT 400A
It is the differential that is different, the housings are the same.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Nope, ive had a 373 in my originally equipped 315 aluminum housing.
Angrey
Coral Gables
2016 GT350
Interesting, US Gear's catalog has an asterisk under their Super 8.8 Ring/Pinion sets that disclaims " *Will NOT fit earlier 8.8-inch straight axles found in previous generations. **Will NOT fit 2015-2017 Mustangs originally equipped with a rear-end housing with factory installed 3.15 gears. "
US Gear makes the FRPP gears, and I'm not so sure they don't supply Ford with the Ring/Pinions for the factory installed units.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
We did it with no issues. They may be insinuating that it is not work with the 315 diff, not necessarily the housing.
