accel
If you google, you'll see that this issue on Mustang and F-150 5.0 was initially very-very often associated with the first oil change.I know that. The problem is, the tick does exist with some of the earlier 5.0L engines, but is most present with the new version. However, the block design and oil passages of this new version is basically identical. The only real change is the PTWA cylinders, and additional DI system. The oil system however, is the same. If this number of engine ticks was a result of oil starvation, it would have been just as prevalent in the original motors. My bet is timing issues creating knock that eventually causes damage, or possibly bad bearings from the get go.
If you really like to figure what the tick was you cannot ignore that history.
It is relatively recent trend for engines to have the tick before the oil change. My 2017 is one of those that ticked from the very beginning.
I wonder if this was a result of preparations for 2018+ generation with engine factory re-tooling. Late 2017 engines might be subject to some of the new processes. Obviously they did not swap the line in one hour.
