battery box
JCN
Indiana
Jim
20 Mustang GT, 23 F150
has anyone had the battery box out of an 18 up, looking to run a wire from battery to trunk for am upcoming sub woofer. There is a rubber grommet on fire wall just in front of inside fuse panel that would be perfect route but it's behind or just below battery and I can't even see it let alone get a hand in there. If the battery box comes out fairly easy it would be handy to use rather than run across to driver side. Thanks Jim
MegaG
NorCal
2018 Royal Crimson Mustang GT A10 Base
I'm sure its not the only video out there...
JCN
JCN
Indiana
Jim
Thanks MegaG, it never occurred to me to hit youtube should've known. I did about 40 years for Norfolk Southern and a lot of that was electronic wiring, you do nice work-very clean set up. Jim
MegaG
NorCal
Lol, that's not me in the video, in fact, based on your Norfolk comment we are far closer in age to each other then you and the gentlemen in the video are. Glad I could help!
JCN
JCN
Indiana
Jim
:cwl: whoops, oh well thanks anyway confirmed what I was thinking of trying! Jim
Michael_vroomvroom
Spain
Michael
Can I ask what the reason for running cables from the battery all the way back to the trunk is?
I have not investigated yet myself, but I hoped at least some of the wires under the trunk lining would be connected to a suitably switched (ignition-on, or accessory) 12v cables. Is that not so?
I planned to hook into a suitable pair so I could add a socket for a 12v mini-refrigerator back in the trunk some day I had the time.
JCN
JCN
Indiana
Jim
I,m putting a small powered sub in trunk. calls for 25amps, am going to run 40 amp supply back this leaves a little for later who knows what. I don't know if you'll find enough all ready there to run a mini fridge but it's worth a try. I'm going to run #8 directly from battery to a bus then #10 to sub.
MegaG
NorCal
I don't know how much current your mini-fridge needs but I would be surprised if the trunk had a large enough wire with excess capacity to run one but to be honest I have never looked at these. Its why most after market car audio installs need dedicated power runs.
There are tables available that specifiy how much current a wire can carry by gauge.
Here's the table for one particular car audio wiring supplier but there are many more out there for more wire sizes then just these common car audio size.
MegaG
NorCal
With the effort it takes to make a power wire pull, its normally not too much more total $ versus the time & effort spent to just run 4 gauge versus 8 gauge or are you real sure that's all you'll ever do back there?
Michael_vroomvroom
Spain
Michael
Well, I might be to optimistic about this, but I hope not. I'll keep this thread in mind when I start looking at it before the summer. Thanks.
I also have a service manual for the 2016 Mustang someone made available for free via a link here. I'm thinking it will have the details, and hopefully they will be similar enough in my 2020 car, though I'll have to verify it of course.
JCN
JCN
Indiana
Jim
ya fairly, the sub pulls 13.5 on a 25 amp fuse. The only other thing I could imagine might be a fuel pump upgrade. The Roush bug is chewing on me pretty hard!:wink:
m3incorp
Georgia/Colorado
James
It took me about 30 minutes to run a 4 gauge cable from the battery to the rear. I did not remove the battery box.
m3incorp
Georgia/Colorado
James
All amplifiers should be wired to the battery. You then run the "remote" turn on wire (blue) to a power source that shuts off when the ignition is not in the run or accessory position.
If you wire it directly to the battery, won't it always be powered on ?
