B&o sub and amp upgrade
Canarcie
NC
Shawn
2021 Ford Mustang gt
No real need to, just to add a subwoofer. Now if upgrading other speakers and adding amps, then definitely go with the PAC Amp Pro.
Right can be different for different situations and needs.
So should I use the back speakers to tap into for the +&- to plug into to lc2 or should I tap into the stock sub it came with in the trunk
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Eh, to each their own but doing it “right” means eliminating the stock bass roll-off which you can’t do tapping into the rear wires. And an LCi2 isn’t necessarily required if he’s adding an amp. Many amps are available with LOCs built in.
m3incorp
Georgia/Colorado
James
I agree. I will say most will not notice that bass roll off at all when tapping into the rear wires.
m3incorp
Georgia/Colorado
James
Please take note, we were referring to using the Amp Pro before the signal reaches your amps. If your amp has both high and low inputs, no need for the lc2.
m3incorp
Georgia/Colorado
James
I missed it but if you have the B&O, no need to mess with the back speakers at all. You tap into the correct wires from the existing subwoofer.
Canarcie
NC
Shawn
So basically pull the stock sub out disconnect the clip and use those wires for the signal to connect to the Lc2
Canarcie
NC
Shawn
I have used regular loc converters on stock systems before even on my f150 but I never had the aftermarket sound system to tap into so I didn’t know if it was little different, I was told Lc2 is good for stock amps for better quality when adding a aftermarket sub and amp
m3incorp
Georgia/Colorado
James
Yes, but the subwoofer is dual coil, so you have to use the correct pairs of wires. I will have to take a look at which ones they are but if you do a search you should be able to find wher I and others describe which pairs to use.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
can you clarify what you’re doing? Are you adding an amp or reusing the stock amp?
m3incorp
Georgia/Colorado
James
Yikes good question. Although, I would never rely on those few watts coming from the stock dsp/amp.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
If I’m understanding correctly you want to add an aftermarket amp and sub. What amp are you looking at? As I stated previously you can get many amps that have high and low level inputs which would make an LoC redundant. You can definitely pull the signal from the stock wiring but you’ll still need to run new power and ground wires. And if you want to eliminate base roll-off you can use a Audio Control Epicenter and one of their amps, or you can use one of their all in one amps that do LoC and bass restoration.
Canarcie
NC
Shawn
Yes I want to add a aftermarket sub and amp and I want to remove the stock sub they put in the trunk .I am using a mb quart mono lock class d to power two 10s in a custom box so I just need to know the best way to power my amp with Lc2i pro . Do I remove the stock sub and tap in to those wires for the inputs to the Lc2
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Yes. There’s a pinned post in this section that shows which wires are which.
Canarcie
NC
Shawn
You said there is a pinned post ? Do you know where that Prost is at or how I can get to it
Cathul
Germany
Peter
Ford Mach-E
Right on top of the sticky threads in this subforum.
