Axle temperature never goes down
cking
17GT350AG/BS-MGW/UPR/ABLIP
I'm not making stuff up got it right from the shop manual. Read the thread OEM Diff cooler install. Even wiring and fault codes. if you have base or tech 2015-16 You don't have diff temp sensor, limp mode would come from tyranny getting hot on track days. The circuit seems robust to me, a pulse modulated pump is used with a shaft speed sensor feed to PCM. It could even be variable speed, the PCM sends a square wave to control pump speed. Although we've only seen one pulse width. it may run at startup to do system check but not confirmed
