Auto, PP and 3.73s from the factory
EFI
Masshole central
5.Br0
I've been told that this is option you can order straight from the factory (not a dealer add on). Looking around in the online configurator I don't see it being an option, nor do I see it in the detailed available options for each trim level.
Is this like a special order or how does one get this combo from the factory?
Skye
≈39N
"Skye" Mach1 N2144
FWIW, Attached is an order guide I reference often.
Unfortunately, the 3.73 appears to be MT only. All AT are 3.55.
I don't see a breakout where one can individually select rear gear.
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
My PP auto is definitely 3.55. With the gearing on the auto I don't think a 3.73 is needed. I could see it being beneficial with the MT.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
Somebody is lying to you.
Richfl01
Bradenton, FL
2021 mustang gt convertible
I have a 2021 GT convertible with auto and ordered the 3.55 rear as an option. The standard gear ratio on the auto is 3.15. If you get the PP2, you get a bunch of stuff including the 3.55 in the auto. For the manual you get the 3.73 for the PP2.
I didn't need or want the PP2...but I did want the 3.55.
I also wanted the black accent package as I think the wheels look great...you can't combine the PP2 and black accent.
Firsttexan
2011 GT500 '19 GT PP1 '13 GT500, 98 GT, 92 LX 5.0
Agreed. MIne too. 3.55 are plenty stiff with the A10.
shogun32
Northern VA
There is no A10 combo with PP2. Strictly manual only. If you mean Mach1 then the auto comes with 3.55 just like every other PP Auto.
