Attention to detail
Dmaster
Georgia
2019 Shelby GT350
I learned a valuable and expensive lesson on paying attention to detail. Swapped out the foam cannon for a different tip to rinse off my car. Then this happened. Always give a spray toward the ground first. I didn’t secure the tip properly on the pressure washer gun.
catchthecarp
STL MO
2017 White Platinum Premium GT
Holy crap! Sometimes you have days where your purpose in life is to serve as a warning to others....... :)
ctandc72
VA
'19 GT 6 speed Base
It just hit the glass? No paint damage?
Sounds like you got lucky. If it had hit the 1/4, dented it, chipped paint, you'd need body work and a blend spray job. Not cheap unless you do it yourself or know someone who does.
Bikeman315
Myrtle Beach, SC
Ira
Unless it’s glare, I see scratches on the door and just below the window. I hope I’m wrong. :frown:
Dmaster
Dmaster
Georgia
2019 Shelby GT350
Just hit the glass, so I got lucky. If it had damaged the paint to the point it needed body or paintwork I would of sold the car.
coreystang
2015 Mustang GT
I did that the other day. But it shot over the car and into the road. Never again will I aim it remotely close to my car again!
Ouch... that sucks. I’ve had the experience of a pressure washer nozzle shooting off at rocket speed, but luckily that was against the vinyl siding on our house...just bounced off it...
Check out eBay - there’s always S550 rear 1/4 glass listed on there for very fair pricing. Trying to buy that through Ford will most likely cost you upwards of $800...
fiveoboy01
Madison, WI
2017 LB GT 400A
Damn. At least the window can be replaced, as opposed to if it had hit a body panel... although I've seen some PDR guys work some real magic on dented panels.
Bikeman315
Myrtle Beach, SC
Ira
