Apple CarPlay Issues
gorgin4325
South Florida
2020 GT Premium
Hi guys,
Has anyone experienced connectivity issues with CarPlay? My connection seems to be hit or miss. Sometimes it connects right up, and sometimes I have to connect/disconnect the cable multiple times for the car to "see" my iPhone. Other times, in the middle of a drive, it just disconnects. I have tried 2 brand new Anker cables, both with the same results.
I will also try one of the standard Apple cables this week. I was also thinking about getting a BT CarPlay device off Amazon, but I really like the fact that I can charge my phone through the cable.
Any thoughts or advice would be appreciated.
Thanks.
larf37
Canada
Larry
2017 Mustang GT Premium Convertible
Hi guys,
Thanks.
Not sure if it is relevant for you but I had issues with CarPlay in my Mustang. It turns out I had a VPN that I use when I travel turned on on my phone and that was messing things up somehow.
gorgin4325
gorgin4325
South Florida
2020 GT Premium
Interesting! I'll try turning my VPN off in the car and see if it gets any better. Thank you!
larf37
Canada
Larry
No problem. I would be interested in hearing if turning the VPN off works for you. I hope it does.
gorgin4325
gorgin4325
South Florida
2020 GT Premium
Well, on the way back from work it decided to work perfectly fine! So we shall see!
larf37
Canada
Larry
Interesting. If I remember correctly mine worked as long as my cell coverage was good but messed up when I lost coverage. Since turning the VPN off I have had no issues at all no matter how the good or bad the cell signal strength is.
gadgtfreek
Fairhope, AL
Jason
2021 GT Premium Shadow Black 10spd Auto
My iPhone 11 Pro has done that once, connected via USB to connecter under climate controls. Had to restart the car. That was early on when I bought it, in Oct-Nov range. Since then I have not had it happen, and have updated Sync several times with new versions.
