Anyone running 19x10 square??
Gst95dsm
Fresno CA
2015 MM EB PP Recaro....
Looks like all the lower end wheels in a 19" are either 8.5 or 10" width. Id like to run a square 10" setup but AMR, lists the 10" as a rear only application. Not sure why....
Budwise
Austin, TX
2015 GT PP
Because their offset is wrong for the front fitment at +48 you probably won't clear the caliper or you may rub the fenderwell on full turn lock. If you want to go that route expect to need a 5-8mm spacer for the fronts.
I'm running 19X10 squared Forgestar F14's without issue but as you know they cost a lot more.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
If you want to run a 19x10 square then rotory forged like what budwise suggested is what you need, the offset and design is catered to allow large caliper fitment clearance.
ronnieb1958
Inglewood, Ca
Ronnie
2015 Ecoboost Premium
19x10 square
how about a 19x10 on 275/35/19 square fit?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
USPSALIMITED
Southern Indiana
G6 GT PP Guard
Did the car feel any different when you installed the Forgestars?
Have stock width 19" CF5's to install when it gets a bit warmer, and curiosity is killing me.
Budwise
Austin, TX
2015 GT PP
Since I was already running the 275 Michelin PSS squared, not really. With the wider rims giving the shoulders of the tires more stability so they should feel more precise in the corners but during DDing I havent noticed much. Once I get on the track I'm sure they'll be fantastic.
