19x10 +35 square?
edrenaline
Ohio
Shane
2020 GT PP1 fastback Shadow Black
I literally just dropped my car off at the tire place, with these exact wheels to put on a 2020 PP1 car and they called me back to warn me about the fitment. I said a bunch of people are running the same setup with no problems, but now I'm worried. MRR M600 19x10 35mm all around with 275/40/19 Michelins Pilot Sport 4 S all around
EFI
Masshole central
5.Br0
What did they say the issue was?
BTW, running 19x10 +34 (+40 with 6mm spacer) and fits just fine as you can see:
emcmtony
Tony
2020 Saleen Mustang S302 White Label
You are NOT going to rub. I have a 1.3 inch lower in the rear and 1.5 in the front. I am running 20x9.5 Front with 275 35r20 and 20x10.5 rear with 305 35r20 and it is perfectly fine. No rubbing. My car came like this from the Saleen upfitter.
edrenaline
Ohio
Shane
Ended up being no problem. When they test-fit just the wheel without the tire in front, they said it was only half an inch from the strut. Darren from MRR had already assured me they would fit, and it turned out fine. I live in small-town Ohio and I don't think they get the chance to install many aftermarket wheels
Salty
Miami
2015 5.0 MT-82, 2019 5.0 10R80
Did you feel you have enough threads to tighten with the 6mm spacer? I know anything after 10mm its suggested to extend the wheel studs.
EFI
Masshole central
5.Br0
Yes, I made sure to check that and counted at least 8 full turns on the lugs when I stopped counting.
I've done 14 track days (at least 3 sessions 20 minutes each) on this setup and have not had any issues with the wheels. FWIW, these are high quality billet custom spacers not the universal crap from AutoZone. I would not use those, or anything thicker.
Salty
Miami
Nice. I assume you found a local shop to do custom spacers?
EFI
Masshole central
5.Br0
Not local, they are from Motorsport Tech. They do custom stuff too, but they also carry many common setups one being the S550 Mustang. So they are specific to the car.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
