Anyone Fixed Trunk Light Not Working, Rear Camera is Fine.
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
My trunk light stopped working, but all other systems are fine. The fuse for the trunk light also appears to control other functions, all which are working correctly.
So they did the recall inspection for the rear camera and that is working fine.
Any suggestions?
Thanks
CVCashmere
PSI
US
16 Mustang GT, 17 F150, 14 Audi Q5
This may be too obvious, but how’s the bulb? It’s an incandescent that is replaceable and not an LED.
G.T.
Asia
Glenn
2016 Ford Mustang GT Premium
I am looking at this too. On sale at Ford till June 30, 25% off!
CVCashmere
CVCashmere
South Jersey
Carl
Update!
When Ford did the harness recall because it was too tight when the trunk opened up, they used a wire loom.
Everything continued to work great for about1.5-2 years, then the light failed.
An independent garage tracked the problem (from a wiring diagram I gave them), and found that the outer side of the loom pinched and eventually cut the trunk light.
Doing a little trouble shooting where the harness flexes at the trunk opening solved the problem. One hour labor charge and my trunk light (with LED bulb) works again!
Reach out to me if you have a similar problem on your vert.
Thanks
CVCashmere
Redcruzer
Redwood City
2015 eco boost premium convertible, Ruby red
Wow, this is exactly why I declined to have the recall done. My harness looked fine and after other recall “mishaps “ with Ford, I told the dealer last month, “Thanks but no thanks”. Got a weird look, didn’t bother to explain.
Johnnybee
Canada
2018 convertible
I received the recall but have not had it done as I have no issues. I also don’t think that my harness is overly tight. What I have found is that Ford managed to install it so that if left alone, when you close the trunk it will get pinched between the lid and the rubber seal on the body. So, I make a habit of moving it toward the centre of the car when closing it to make sure it clears.
